Pular para o conteúdo principal
Introdução
This will guide you through the process of replacing your logic board.
Peças
Nenhum componente especificado.
  1. Remove the parallel port cover on the back of the PlayStation.
    • Remove the parallel port cover on the back of the PlayStation.
  2. Flip over the PlayStation and remove the six screws from the bottom.
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. Turn the PlayStation upright. Remove the cover by lifting it up.
    • Turn the PlayStation upright. Remove the cover by lifting it up.
  4. Carefully disconnect the gold-colored ribbon cable from it's connector.
    • Carefully disconnect the gold-colored ribbon cable from it's connector.
    • To avoid damaging the cable, pull it by the white, reinforced tab.
  5. Disconnect the second cable by pulling up on the plastic connector at the end.
    • Disconnect the second cable by pulling up on the plastic connector at the end.
  6. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  7. Lift the optical drive off of the PlayStation.
    • Lift the optical drive off of the PlayStation.
  8. Remove the four screws from the logic board's metal cover.
    • Remove the four screws from the logic board's metal cover.
  9. Detach power supply connector from logic board by pulling on the plastic tab.
    • Detach power supply connector from logic board by pulling on the plastic tab.
  10. Detach white ribbon cable from logic board by gently lifting on it.
    • Detach white ribbon cable from logic board by gently lifting on it.
  11. With one hand, hold the main board’s protective metal cover. With your other hand, wedge the spudger in between the right side of the protective cover and the thin metal clamps that surround it.
    • With one hand, hold the main board’s protective metal cover. With your other hand, wedge the spudger in between the right side of the protective cover and the thin metal clamps that surround it.
    • With the spudger in place, gently lift the upper portion of the metal cover. The cover should detach from the right side.
  12. Using the same process from the previous step, wedge the spudger between the clamps and metal cover on the bottom side (as shown in the picture).
    • Using the same process from the previous step, wedge the spudger between the clamps and metal cover on the bottom side (as shown in the picture).
    • With your other hand, pull up on the top right corner of the metal cover to lift it off.
  13. Remove the last four screws from the logic board.
    • Remove the last four screws from the logic board.
  14. Lift the logic board out of the PlayStation and replace with a new logic board.
    • Lift the logic board out of the PlayStation and replace with a new logic board.
Conclusão
13 outras pessoas concluíram este guia.
JakeDeschamps
Membro desde: 28-10-2009
1.065 reputação
5 Guias de autoria
Equipe
Cal Poly, Team 5-2, Regan Fall 2009 Membro de Cal Poly, Team 5-2, Regan Fall 2009
CPSU-REGAN-F09S5G2
5 Membros
14 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 65
Todo: 18,675
