Introdução
This will repair your SCPH-5501 without buying a new KSM-440-ADM laser off of ebay.
O que você precisa
Remove the parallel port cover on the back of the PlayStation.
Flip over the PlayStation and remove the six screws from the bottom.
Turn the PlayStation upright. Remove the cover by lifting it up.
Disconnect the second cable by pulling up on the plastic connector at the end.
Remove the 2 screws and take the black bottom piece of the old Optical drive.
Take the new Optical drive from either a SCPH-7501 or an SCPH-9001.
Gently pull on the orange ribbon, but not too much or you could rip it.
