Introdução
This will guide you through the replacement of your controller port.
Peças
Não são necessárias peças.
  1. Remove the parallel port cover on the back of the PlayStation.
    • Remove the parallel port cover on the back of the PlayStation.
  2. Flip over the PlayStation and remove the six screws from the bottom.
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Turn the PlayStation upright. Remove the cover by lifting it up.
    • Turn the PlayStation upright. Remove the cover by lifting it up.
  5. Remove the two screws securing the controller port to the case. Remove the two screws securing the controller port to the case.
    • Remove the two screws securing the controller port to the case.
  6. Gently disconnect the ribbon cable from the logic board. This is done by pulling on the blue area of the cable near the connector.
    • Gently disconnect the ribbon cable from the logic board. This is done by pulling on the blue area of the cable near the connector.
  7. Remove and replace the controller port.
    • Remove and replace the controller port.
Conclusão
6 outras pessoas concluíram este guia.
JakeDeschamps
1.047 reputação
5 Guides authored
Equipe
Cal Poly, Team 5-2, Regan Fall 2009 Membro de Cal Poly, Team 5-2, Regan Fall 2009
CPSU-REGAN-F09S5G2
5 Membros
14 Guides authored
I try replacing the controller and still wouldn't play memory cards.
redevil19 - Responder
I changed the controller port but the psx still doesn't recognize any controller. Both controller port and ribbon cable work perfect in other console. I wonder which components on the mother board are related with the controller ports so I can check them with a tester.
Daniel Prieto - Responder
I replaced the PS605 fuse and now the controllers work again! Thanks to this video https://www.youtube.com/watch?v=HdULot5F...
Daniel Prieto -
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 86
Todo: 19,033
