Ir para o conteúdo principal
PlayStation Classic Controller Port Replacement
O que você precisa
  1. PlayStation Classic Controller Port Replacement, Motherboard: passo 1, imagem 1 %32
    • Flip the console so its back is facing up.
  2. PlayStation Classic Controller Port Replacement: passo 2, imagem 1 %32
    • Remove the five 3mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. PlayStation Classic Controller Port Replacement: passo 3, imagem 1 %32 PlayStation Classic Controller Port Replacement: passo 3, imagem 2 %32 PlayStation Classic Controller Port Replacement: passo 3, imagem 3 %32
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. PlayStation Classic Controller Port Replacement: passo 4, imagem 1 %32
    • Unscrew the motherboard's five 3mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. PlayStation Classic Controller Port Replacement: passo 5, imagem 1 %32 PlayStation Classic Controller Port Replacement: passo 5, imagem 2 %32 PlayStation Classic Controller Port Replacement: passo 5, imagem 3 %32
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. PlayStation Classic Controller Port Replacement: passo 6, imagem 1 %32 PlayStation Classic Controller Port Replacement: passo 6, imagem 2 %32 PlayStation Classic Controller Port Replacement: passo 6, imagem 3 %32
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
  7. PlayStation Classic Controller Port Replacement, Controller Port: passo 7, imagem 1 %32 PlayStation Classic Controller Port Replacement, Controller Port: passo 7, imagem 2 %32
    • Identify the damaged or faulty controller port and simply use your fingers to remove.
Conclusão
Uma outra pessoa concluiu este guia.
Maxwell Webb
Membro desde: 04/22/19
631 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S2-G8, Maness Spring 2019 Membro de Cal Poly, Team S2-G8, Maness Spring 2019
CPSU-MANESS-S19S2G8
Membros da 2
Autoria de 22 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 34
Duração total: 1,749
