Ir para o conteúdo principal
Introdução
Follow this guide to replace the Wi-Fi antenna on your Sony Playstation 4.
Unplug your PS4 before beginning any repairs.
  1. Flip the PS4 upside-down with the back side facing towards you.
    • Flip the PS4 upside-down with the back side facing towards you.
  2. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  3. Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws. Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  4. Remove the four 7.2 mm Torx security screws on the back of the PS4. Remove the four 7.2 mm Torx security screws on the back of the PS4.
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  5. Use your thumbs to lift the lower case up and off the PS4. The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  6. Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard. Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
  7. Remove three 9.7 mm Torx security screws. Remove two 41 mm Phillips screws and brackets.
    • Remove three 9.7 mm Torx security screws.
    • Remove two 41 mm Phillips screws and brackets.
  8. Lift the power supply straight up and out of the PS4. The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it. During reassembly, ensure the prongs are aligned, then press the power supply into place.
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
  9. Use the tip of a spudger to disconnect the antenna cable from the motherboard. Use the tip of a spudger to disconnect the antenna cable from the motherboard.
    • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
  10. Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides. Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides. Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
    • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
  11. Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable. Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable. Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
    • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
  12. Remove the 9.7 mm Torx security screw securing the antenna. Remove the 9.7 mm Torx security screw securing the antenna.
    • Remove the 9.7 mm Torx security screw securing the antenna.
  13. Remove the Wi-Fi antenna. Remove the Wi-Fi antenna.
    • Remove the Wi-Fi antenna.
Conclusão
80 outras pessoas concluíram este guia.
Sam Omiotek
Membro desde: 25/02/2019
36.401 Reputação
233 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
139 Membros
15.650 Guias de autoria
105 comentários
Took me about 10mins with this guide. Super easy. New parts in and working wonderfully. Ty ifixit!
luckycha87 - Responder
My wireless controlers wasn't recognised. I change the WiFi connector but this problem is not resoleved yet.
Frederic Morelli - Responder
Hi Frederic! Have you tried resetting the controller? Have you tried any other controllers to see if they work? Also, are you sure the battery in your controller is good and it's charged up?
TronicsFix -
Hello my controller has a hard time working from 4 feet away from my console and disconnecting. Im thinking of doing this hopefully it works. Is the bluetooth and wifi part the same thing because my wifi doesnt seem to pick up my wireless router.
ludracing - Responder
Yes, the wifi and bluetooth antenna is the same.
TronicsFix -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 45
Últimos 7 dias: 317
Últimos 30 dias: 1,482
Duração total: 129,835
