Ir para o conteúdo principal
PlayStation 4 Slim Hard Drive Replacement
O que você precisa
  1. PlayStation 4 Slim Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 PlayStation 4 Slim Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Slide your thumb to the right to remove the plastic cover.
  2. PlayStation 4 Slim Hard Drive Replacement: passo 2, imagem 1 %32 PlayStation 4 Slim Hard Drive Replacement: passo 2, imagem 2 %32
    • Remove the silver 6 mm #0 Phillips screw that holds the hard drive caddy in place using your screwdriver.
    • This screw is very important as it ensures the drive does not come loose from the connector during operation.
  3. PlayStation 4 Slim Hard Drive Replacement: passo 3, imagem 1 %32 PlayStation 4 Slim Hard Drive Replacement: passo 3, imagem 2 %32 PlayStation 4 Slim Hard Drive Replacement: passo 3, imagem 3 %32
    • Pull out the black glossy tape handle using your fingers.
    • Remove the caddy from the bay.
  4. PlayStation 4 Slim Hard Drive Replacement: passo 4, imagem 1 %32 PlayStation 4 Slim Hard Drive Replacement: passo 4, imagem 2 %32 PlayStation 4 Slim Hard Drive Replacement: passo 4, imagem 3 %32
    • Remove all four 8 mm Phillips #0 screws from the hard drive caddy (two on each side).
  5. PlayStation 4 Slim Hard Drive Replacement: passo 5, imagem 1 %32 PlayStation 4 Slim Hard Drive Replacement: passo 5, imagem 2 %32
    • Slide your hand under the sled opening near the black tape handle, and press one of your fingers against the slate drive to push it up.
    • Carefully extract the hard drive from the caddy.
  6. PlayStation 4 Slim Hard Drive Replacement: passo 6, imagem 1 %32 PlayStation 4 Slim Hard Drive Replacement: passo 6, imagem 2 %32
    • Place your replacement hard drive or solid-state drive into the caddy.
    • Make sure the drive is upside with the connector's golden pins facing up like so.
    • Also be sure the connector is facing away from the black tape handle. This and the above point will ensure proper connection to the Playstation 4.
    • If installing a solid-state drive, make sure the screw holes of the sled and the drive are aligned properly before screwing back in.
    • This isn't a problem with 2.5" hard disk drives since the thickness allows for proper alignment during placement.
Conclusão
To reassemble your device, follow these instructions in reverse order starting from Step 4.
Be sure to have a USB stick ready with an official PS4 firmware update file from Sony's website to reinstall the system software on your new hard disk or solid state drive. Follow Sony's instructions for formatting the USB as well.
10 outras pessoas executaram este guia.
Jordan Crooks
Membro desde: 02/02/24
373 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-7, Andersen Winter 2024 Membro de UC Davis, Team 3-7, Andersen Winter 2024
UCD-ANDERSEN-W24S3G7
Membros da 2
Autoria de 6 guias
2 comentários
I need help why is my ps4 slim not turning on, all it does Is show the Play Station logo then the screen is black then turns off?
Henry Ramsey - Responder
This tutorial for some reason fails to mention the important step that you need to reinstall the system firmware using a USB drive. Other tutorials are out there though that don't skip this important piece of information.
Anon999 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 34
Últimos 7 dias: 234
Últimos 30 dias: 979
Duração total: 8,253
