O que você precisa
Start by flipping the PS4 Pro over its top.
Remove the plastic panel covering the drive bay, using the tab next to the Ethernet port.
Remove the Phillips #0 screw securing the hard drive caddy to the chassis.
Slide the hard drive caddy out.
Remove the four Phillips #0 screws securing the hard drive to the caddy.
63 outras pessoas executaram este guia.
7 comentários
i want to change the hard drive in my ps4 to a 5tb (2.5”) but does this transfer trophies if i don’t use internet (PSN) to save them?
ANY HELP!!!!
hope you already solve this issue, but if not, there’s a backup option to save or backup them to a USB drive (thumb drive)
Does the ps4 slim hard drive fit in a ps4 pro
Yes the slim hard drive fits into the pro
Is there a known capacity limit, or will anything that fits in the slot work?
