Introdução
Follow this guide to replace the power supply on your Sony Playstation 4.
Unplug your PS4 before beginning any repairs.
O que você precisa
Ferramenta utilizada neste passo:Tweezers$4.99
Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
Remove the four 7.2 mm T8 Torx security screws on the back of the PS4.
Remove three 9.7 mm-long TR8 Torx security screws.
Remove two 41 mm-long Phillips screws and brackets.
222 outras pessoas executaram este guia.
77Comentários do guia
Gonna do this tomorrow, I'm just hoping this is what's wrong with it.
A few months ago something popped in the system and I smelt a burning scent.
Bro,did it work for you?
I have same problem
I have same thing.
Just be careful when pulling up power supply on the left side facing you when Ps4 is upside-down.
Oui c’est exactement ça j’ai arraché un câble.
Est-ce que quand je vais commander le bloc d’alimentation j’aurais j’aurai un autre ?
