Ir para o conteúdo principal
Introdução
Follow this guide to replace the motherboard on your Sony Playstation 4.
The motherboard and optical drive are paired, thus replacing only the motherboard will result in a non-functioning device. Be sure to order the correct paired optical drive and motherboard for your PS4 model and replace both.
Unplug your PS4 before beginning any repairs.
  1. Grip the PS4 with both hands along the gap in the top cover. Push the glossy side of the top cover with your thumbs until it pops to the side. Lift the glossy top cover up and back to remove it from the PS4.
    • Grip the PS4 with both hands along the gap in the top cover.
    • Push the glossy side of the top cover with your thumbs until it pops to the side.
    • Lift the glossy top cover up and back to remove it from the PS4.
  2. Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure. Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
  3. Pull the hard drive bracket out of the enclosure. Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock. Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock.
    • Pull the hard drive bracket out of the enclosure.
    • Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock.
  4. Flip the PS4 upside-down with the back side facing towards you.
    • Flip the PS4 upside-down with the back side facing towards you.
  5. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  6. Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws. Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  7. Remove the four 7.2 mm Torx security screws on the back of the PS4. Remove the four 7.2 mm Torx security screws on the back of the PS4.
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  8. Use your thumbs to lift the lower case up and off the PS4. The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  9. Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard. Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
  10. Remove three 9.7 mm Torx security screws. Remove two 41 mm Phillips screws and brackets.
    • Remove three 9.7 mm Torx security screws.
    • Remove two 41 mm Phillips screws and brackets.
  11. Lift the power supply straight up and out of the PS4. The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it. During reassembly, ensure the prongs are aligned, then press the power supply into place.
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
  12. Use the tip of a spudger to disconnect the antenna cable from the motherboard. Use the tip of a spudger to disconnect the antenna cable from the motherboard.
    • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
  13. Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides. Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides. Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
    • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
  14. Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable. Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable. Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
    • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
  15. Remove the 9.7 mm Torx security screw securing the antenna. Remove the 9.7 mm Torx security screw securing the antenna.
    • Remove the 9.7 mm Torx security screw securing the antenna.
  16. Remove the Wi-Fi antenna. Remove the Wi-Fi antenna.
    • Remove the Wi-Fi antenna.
  17. Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive. Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab. You do not need to press the metal lever when inserting the ribbon cable back in. You will hear a click once it is fully inserted.
    • Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive.
    • Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab.
    • You do not need to press the metal lever when inserting the ribbon cable back in. You will hear a click once it is fully inserted.
  18. Use your fingernail to press down the metal release lever for the ribbon cable connected to the motherboard. Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab. Set the ribbon cable aside for reassembly.
    • Use your fingernail to press down the metal release lever for the ribbon cable connected to the motherboard.
    • Set the ribbon cable aside for reassembly.
  19. Use your fingers or a pair of tweezers to disconnect the optical drive cable from the motherboard. Use your fingers or a pair of tweezers to disconnect the optical drive cable from the motherboard.
    • Use your fingers or a pair of tweezers to disconnect the optical drive cable from the motherboard.
  20. Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place. Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place. Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place.
    • Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place.
  21. Remove the four screws securing the optical drive. Three 9.7 mm Torx screws
    • Remove the four screws securing the optical drive.
    • Three 9.7 mm Torx screws
    • One 6.2 mm Phillips screw
  22. Lift the optical drive straight up and out of the PS4. Lift the optical drive straight up and out of the PS4.
    • Lift the optical drive straight up and out of the PS4.
  23. Remove the two 9.7 mm Torx screws securing the upper case. Remove the two 9.7 mm Torx screws securing the upper case.
    • Remove the two 9.7 mm Torx screws securing the upper case.
  24. Lift the upper case up and back to remove it from the PS4. The upper case in held in place by plastic tabs on the front side. It will take significant force to separate them. The upper case in held in place by plastic tabs on the front side. It will take significant force to separate them.
    • Lift the upper case up and back to remove it from the PS4.
    • The upper case in held in place by plastic tabs on the front side. It will take significant force to separate them.
  25. Remove the twelve 9.7 mm Torx screws securing the upper EMI shield. Remove the twelve 9.7 mm Torx screws securing the upper EMI shield.
    • Remove the twelve 9.7 mm Torx screws securing the upper EMI shield.
  26. This step shows you how to properly unscrew the pressure plate. Remove the two 15.6 mm Phillips screws. Gradually unscrew the pressure plate by turning each screw one half turn at a time.
    • This step shows you how to properly unscrew the pressure plate.
    • Remove the two 15.6 mm Phillips screws.
    • Gradually unscrew the pressure plate by turning each screw one half turn at a time.
    • Alternate between the two screws to maintain even pressure on the pressure plate.
    • Do not unscrew one side completely before unscrewing the other side or you may damage the processor.
  27. Remove the pressure plate.
    • Remove the pressure plate.
  28. Remove the upper EMI shield. Remove the upper EMI shield.
    • Remove the upper EMI shield.
  29. Insert the flat end of a spudger in between the fan cable and the motherboard. Twist the spudger to lift the connector straight up and disconnect it from the motherboard.
    • Insert the flat end of a spudger in between the fan cable and the motherboard.
    • Twist the spudger to lift the connector straight up and disconnect it from the motherboard.
  30. Grab the edge of the motherboard on the front of the PS4. Lift the motherboard until the USB ports clear the PS4 case.
    • Grab the edge of the motherboard on the front of the PS4.
    • Lift the motherboard until the USB ports clear the PS4 case.
  31. Lift the motherboard out from the PS4. Apply a new layer of thermal paste to the processor before installing a motherboard using this guide. Failure to properly install new thermal paste will cause your PS4 to overheat.
    • Lift the motherboard out from the PS4.
    • Apply a new layer of thermal paste to the processor before installing a motherboard using this guide.
    • Failure to properly install new thermal paste will cause your PS4 to overheat.
    • Insert the I/O side of the Motherboard in first, then lower the other side in.
Conclusão
168 outras pessoas concluíram este guia.
Sam Omiotek
Membro desde: 25/02/2019
30.637 Reputação
200 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
140 Membros
17.052 Guias de autoria
14 comentários
Regarding the three wire plug in step 20 - is there a good way to repair this piece if, say, you pulled the wires out of the connector by accident? is there a place to get a replacement part?
Ryan Statz - Responder
I have tried to replace the hdmi port however being somewhat of an idiot I slipped and knocked off onto the little black squares just behind the port on the left hand side. Does anyone know what these are?
Geoff Parker - Responder
contacts of the motherboard
lillarrypimp1993 -
You may be talking about capacitors that are critically important for the unit to function.
South30 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 58
Últimos 7 dias: 508
Últimos 30 dias: 2,091
Duração total: 245,541
