Ir para o conteúdo principal
PlayStation 3 Super Slim Wi-Fi Antennas Replacement
O que você precisa
  1. PlayStation 3 Super Slim Wi-Fi Antennas Replacement, Power Supply Unit: passo 1, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement, Power Supply Unit: passo 1, imagem 2 %32
    • Remove the side HDD bay cover by sliding the panel towards the back of the device.
    • The bay cover is found on the right side of the device.
    Just wanted to add: the HDD bay cover isn't on the right all the time, it varies with each unit. The side without the rubber PS logo is the bay cover.
    Yash - Responder
    I just wanted to add that the above is not correct either
    My PS3 Super Slim Mdel No. CECH-4004A has the removable PS logo rubber seal on the left side while the HDD is housed behind the right side (with no rubber PS logo seal)
    Eoin - Responder
    My p3 just went off it goes on but then it just shut down
    Chadley Abrahams - Responder
  2. PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 2, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 2, imagem 2 %32
    • Remove all three black 9.8mm long screws with a T-8 security screwdriver.
    • Remove the blue 7.9mm long screw with a Phillips #1 screwdriver.
  3. PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 3, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 3, imagem 2 %32
    • Pull on the tab to remove the HDD.
    • The HDD should be removed and stored carefully to prevent damage to data.
  4. PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 4, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 4, imagem 2 %32
    • On the bottom of the device, pry out the three rubber feet covers with the metal spudger.
    • Remove the four black 36.3mm long screws underneath with a Phillips #1 screwdriver.
    • One screw is located underneath the warranty sticker. This sticker can either be peeled off or punctured through with a screwdriver.
  5. PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 5, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 5, imagem 2 %32
    • On the top of the device, unlatch the hook on the furthest right beneath the front panel, lift the panel slightly and apply pressure.
    • Unlatch the second right-side hook by sliding a plastic opening tool in the marked area.
    • Slide the panel to the left to unlatch the rest of the hooks.
    • This is probably the most difficult part of the procedure. If you cannot unlatch the hook on the front panel, you can attempt to pry all the hooks off. However, do this at your own risk, as these hooks break easily.
    Getting these on is harder than getting them off.
    Jake - Responder
  6. PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 6, imagem 1 %32
    • Remove the back panel by pressing down the tab on the right side of the device, and sliding the panel to the left.
  7. PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 7, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 7, imagem 2 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 7, imagem 3 %32
    • Remove the five silver 20.8mm long screws with a Phillips #1 screwdriver.
    • Remove the two black 9.9mm long screws in the disc reader with a T-8 security screwdriver.
    • Remove the top black plastic shell.
  8. PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 8, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 8, imagem 2 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 8, imagem 3 %32
    • Move the optical drive to the side to reveal one of the silver 8.8mm long screws.
    • Remove the two silver 8.8mm long screws on either side with a Phillips #1 screwdriver.
    be careful, the fiber-optic cables come out easily and are a pain to put back in
    tucker hartman - Responder
  9. PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 9, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 9, imagem 2 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 9, imagem 3 %32
    • Remove the cable from the plug and remove the wires from the two plastic hooks.
    • When removing the cable from the plug, pull on the plastic male connecter, not on the wires.
    • Remove the power supply unit.
    The left side of the PSU sits on two long metal prongs so you may need to pull a little to get it lose but you should be able to pull the whole unit in an upward motion
    Matthew Symmons - Responder
  10. PlayStation 3 Super Slim Wi-Fi Antennas Replacement, Optical Drive: passo 10, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement, Optical Drive: passo 10, imagem 2 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement, Optical Drive: passo 10, imagem 3 %32
    • Remove the front white flex-ribbon cable by pulling upward from its base.
    • Remove the black and blue flex-ribbon cable behind it by pulling upward on the black tab, then pulling out the cable.
    Para Que son esos cables flex
    Enrique Luna - Responder
  11. PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 11, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 11, imagem 2 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 11, imagem 3 %32
    • Rotate the device 180 degrees.
    • Remove the back white flex-ribbon cable by pulling upward from its base.
    • Remove the optical drive.
  12. PlayStation 3 Super Slim Wi-Fi Antennas Replacement, Wi-Fi Antennas: passo 12, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement, Wi-Fi Antennas: passo 12, imagem 2 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement, Wi-Fi Antennas: passo 12, imagem 3 %32
    • Locate the white flex ribbon cable that connects the power button to the motherboard. Pull this cable out from the motherboard end.
    • Remove the five black 8.3mm long screws with a Phillips #1 screwdriver.
    • Remove the two silver 12.8mm long screws with a Phillips #1 screwdriver.
    • Remove the device from the bottom shell casing.
  13. PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 13, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 13, imagem 2 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 13, imagem 3 %32
    • Remove the two black 8.3mm long screws with a Phillips #1 screwdriver from the Wi-Fi antennas.
    • Lift the Wi-Fi antennas off their mount.
  14. PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 14, imagem 1 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 14, imagem 2 %32 PlayStation 3 Super Slim Wi-Fi Antennas Replacement: passo 14, imagem 3 %32
    • Use a plastic opening tool to remove the Wi-Fi wires from their sockets on the motherboard.
    • Remove the wires from the hooks around the motherboard and fan cover to completely remove the antennas.
    • The Wi-Fi antennas' ports are labeled B and W on the motherboard for reassembly.
    • To insert your new Wi-Fi antennas, insert the wires of your replacement Wi-Fi antennas into each socket, feed the wires through the hooks, and install the antennas on their mount.
Conclusão
13 outras pessoas executaram este guia.
Joseph O'Connor
Membro desde: 04/14/16
2.383 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 34-13, Maness Spring 2016 Membro de Cal Poly, Team 34-13, Maness Spring 2016
CPSU-MANESS-S16S34G13
Membros da 4
Autoria de 21 guias
4 comentários
Hola que tal,abri la ps3 pero solamente tenia 1 cable la angena de wifi,sera que es asi? Por que en las imagenes que nos muestra son dos negro y blanco yo solamente tengo el negro.se podria hacer algo?
alexis cavalieri - Responder
A mi me pasa lo mismo tengo una ps3 Super Slim con un solo cable y solamente tiene un solo conector que es el de BT
Joss1995 -
Excelente trabajo!! muy bien explicado ! eternamente agradecido
angel adrian vera - Responder
I would remove the disk drive before removing the PSU. Moving it over risks damaging the ribbon cables. Other than that, good guide.
Donovan Carlson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 60
Últimos 30 dias: 245
Duração total: 15,855
