Ir para o conteúdo principal
PlayStation 3 Super Slim Fan Replacement
O que você precisa
  1. PlayStation 3 Super Slim Fan Replacement, Power Supply Unit: passo 1, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement, Power Supply Unit: passo 1, imagem 2 %32
    • Remove the side HDD bay cover by sliding the panel towards the back of the device.
    • The bay cover is found on the right side of the device.
  2. PlayStation 3 Super Slim Fan Replacement: passo 2, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement: passo 2, imagem 2 %32
    • Remove all three black 9.8mm long screws with a T-8 security screwdriver.
    • Remove the blue 7.9mm long screw with a Phillips #1 screwdriver.
  3. PlayStation 3 Super Slim Fan Replacement: passo 3, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement: passo 3, imagem 2 %32
    • Pull on the tab to remove the HDD.
    • The HDD should be removed and stored carefully to prevent damage to data.
  4. PlayStation 3 Super Slim Fan Replacement: passo 4, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement: passo 4, imagem 2 %32
    • On the bottom of the device, pry out the three rubber feet covers with the metal spudger.
    • Remove the four black 36.3mm long screws underneath with a Phillips #1 screwdriver.
    • One screw is located underneath the warranty sticker. This sticker can either be peeled off or punctured through with a screwdriver.
  5. PlayStation 3 Super Slim Fan Replacement: passo 5, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement: passo 5, imagem 2 %32
    • On the top of the device, unlatch the hook on the furthest right beneath the front panel, lift the panel slightly and apply pressure.
    • Unlatch the second right-side hook by sliding a plastic opening tool in the marked area.
    • Slide the panel to the left to unlatch the rest of the hooks.
    • This is probably the most difficult part of the procedure. If you cannot unlatch the hook on the front panel, you can attempt to pry all the hooks off. However, do this at your own risk, as these hooks break easily.
  6. PlayStation 3 Super Slim Fan Replacement: passo 6, imagem 1 %32
    • Remove the back panel by pressing down the tab on the right side of the device, and sliding the panel to the left.
  7. PlayStation 3 Super Slim Fan Replacement: passo 7, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement: passo 7, imagem 2 %32 PlayStation 3 Super Slim Fan Replacement: passo 7, imagem 3 %32
    • Remove the five silver 20.8mm long screws with a Phillips #1 screwdriver.
    • Remove the two black 9.9mm long screws in the disc reader with a T-8 security screwdriver.
    • Remove the top black plastic shell.
  8. PlayStation 3 Super Slim Fan Replacement: passo 8, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement: passo 8, imagem 2 %32 PlayStation 3 Super Slim Fan Replacement: passo 8, imagem 3 %32
    • Move the optical drive to the side to reveal one of the silver 8.8mm long screws.
    • Remove the two silver 8.8mm long screws on either side with a Phillips #1 screwdriver.
  9. PlayStation 3 Super Slim Fan Replacement: passo 9, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement: passo 9, imagem 2 %32 PlayStation 3 Super Slim Fan Replacement: passo 9, imagem 3 %32
    • Remove the cable from the plug and remove the wires from the two plastic hooks.
    • When removing the cable from the plug, pull on the plastic male connecter, not on the wires.
    • Remove the power supply unit.
  10. PlayStation 3 Super Slim Fan Replacement, Optical Drive: passo 10, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement, Optical Drive: passo 10, imagem 2 %32 PlayStation 3 Super Slim Fan Replacement, Optical Drive: passo 10, imagem 3 %32
    • Remove the front white flex-ribbon cable by pulling upward from its base.
    • Remove the black and blue flex-ribbon cable behind it by pulling upward on the black tab, then pulling out the cable.
  11. PlayStation 3 Super Slim Fan Replacement: passo 11, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement: passo 11, imagem 2 %32 PlayStation 3 Super Slim Fan Replacement: passo 11, imagem 3 %32
    • Rotate the device 180 degrees.
    • Remove the back white flex-ribbon cable by pulling upward from its base.
    • Remove the optical drive.
  12. PlayStation 3 Super Slim Fan Replacement, Wi-Fi Antennas: passo 12, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement, Wi-Fi Antennas: passo 12, imagem 2 %32 PlayStation 3 Super Slim Fan Replacement, Wi-Fi Antennas: passo 12, imagem 3 %32
    • Locate the white flex ribbon cable that connects the power button to the motherboard. Pull this cable out from the motherboard end.
    • Remove the five black 8.3mm long screws with a Phillips #1 screwdriver.
    • Remove the two silver 12.8mm long screws with a Phillips #1 screwdriver.
    • Remove the device from the bottom shell casing.
  13. PlayStation 3 Super Slim Fan Replacement: passo 13, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement: passo 13, imagem 2 %32 PlayStation 3 Super Slim Fan Replacement: passo 13, imagem 3 %32
    • Remove the two black 8.3mm long screws with a Phillips #1 screwdriver from the Wi-Fi antennas.
    • Lift the Wi-Fi antennas off their mount.
  14. PlayStation 3 Super Slim Fan Replacement: passo 14, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement: passo 14, imagem 2 %32 PlayStation 3 Super Slim Fan Replacement: passo 14, imagem 3 %32
    • Use a plastic opening tool to remove the Wi-Fi wires from their sockets on the motherboard.
    • Remove the wires from the hooks around the motherboard and fan cover to completely remove the antennas.
    • The Wi-Fi antennas' ports are labeled B and W on the motherboard for reassembly.
    • To insert your new Wi-Fi antennas, insert the wires of your replacement Wi-Fi antennas into each socket, feed the wires through the hooks, and install the antennas on their mount.
  15. PlayStation 3 Super Slim Fan Replacement, Fan: passo 15, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement, Fan: passo 15, imagem 2 %32 PlayStation 3 Super Slim Fan Replacement, Fan: passo 15, imagem 3 %32
    • Remove the two black 14.5mm long screws with a Phillips #1 screwdriver from the center of the bottom metal casing.
    • Remove the four silver 8.7mm long screws with a Phillips #1 screwdriver around the edges of the bottom metal casing.
    • Remove the bottom metal casing.
  16. PlayStation 3 Super Slim Fan Replacement: passo 16, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement: passo 16, imagem 2 %32 PlayStation 3 Super Slim Fan Replacement: passo 16, imagem 3 %32
    • Remove the fan wire from its plug on the top metal casing.
    • When removing the wire, do not pull from the wire. Instead, pull from the white plastic male connecter.
    • Remove the motherboard from the top metal casing. Lift from the side with the two USB plugs to avoid damaging the four back ports.
    • There is a thermal compound between the top metal casing and the motherboard in the center, so you may have to apply more force than usual. Do not force the two pieces apart, but slowly apply more and more pressure until the adhesive gives.
    • During reassembly, remember to replace the old thermal compound, as it cannot be reused.
  17. PlayStation 3 Super Slim Fan Replacement: passo 17, imagem 1 %32 PlayStation 3 Super Slim Fan Replacement: passo 17, imagem 2 %32 PlayStation 3 Super Slim Fan Replacement: passo 17, imagem 3 %32
    • On the bottom of the top metal casing, remove the three black 8.0mm long screws with a Phillips #1 screwdriver.
    • Remove the fan from the plastic cover.
Conclusão
Install the replacement fan. To reassemble your device, follow these instructions in reverse order.
38 outras pessoas executaram este guia.
Joseph O'Connor
Membro desde: 04/14/16
2.269 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 34-13, Maness Spring 2016 Membro de Cal Poly, Team 34-13, Maness Spring 2016
CPSU-MANESS-S16S34G13
Membros da 4
Autoria de 21 guias
Um comentário
Thanks for this fan tutorial I have not been able to find any on YouTube about taking apart the fan for cleaning the heat sync's and fan blades it self. So thank you so very much.
Steven Littchum - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 29
Últimos 7 dias: 93
Últimos 30 dias: 387
Duração total: 28,458
