Introdução
Use this guide to replace the PlayStation 3 Slim's single cooling fan.
O que você precisa
Turn the PS3 over and lay it on its backside.
Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
Pull the fan cables upward to lift the fan connector up and out of its socket on the motherboard.
56 outras pessoas executaram este guia.
