Ir para o conteúdo principal
PlayStation 3 Slim Antennas Replacement
O que você precisa
  1. PlayStation 3 Slim Antennas Replacement, Top Cover: passo 1, imagem 1 %32
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Antennas Replacement: passo 2, imagem 1 %32 PlayStation 3 Slim Antennas Replacement: passo 2, imagem 2 %32
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Antennas Replacement: passo 3, imagem 1 %32
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Antennas Replacement: passo 4, imagem 1 %32
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Antennas Replacement: passo 5, imagem 1 %32 PlayStation 3 Slim Antennas Replacement: passo 5, imagem 2 %32
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. PlayStation 3 Slim Antennas Replacement, Power Supply: passo 6, imagem 1 %32 PlayStation 3 Slim Antennas Replacement, Power Supply: passo 6, imagem 2 %32
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  7. PlayStation 3 Slim Antennas Replacement: passo 7, imagem 1 %32
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
  8. PlayStation 3 Slim Antennas Replacement: passo 8, imagem 1 %32
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
  9. PlayStation 3 Slim Antennas Replacement: passo 9, imagem 1 %32
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  10. PlayStation 3 Slim Antennas Replacement: passo 10, imagem 1 %32 PlayStation 3 Slim Antennas Replacement: passo 10, imagem 2 %32
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
  11. PlayStation 3 Slim Antennas Replacement, Antennas: passo 11, imagem 1 %32 PlayStation 3 Slim Antennas Replacement, Antennas: passo 11, imagem 2 %32
    • If present, remove the pieces of tape securing the antenna cables to the fan shroud, Blu-ray drive, and top shield.
  12. PlayStation 3 Slim Antennas Replacement: passo 12, imagem 1 %32
    • Remove the two 6.2 mm Phillips screws securing the antennas to the lower case.
  13. PlayStation 3 Slim Antennas Replacement: passo 13, imagem 1 %32 PlayStation 3 Slim Antennas Replacement: passo 13, imagem 2 %32
    • Use the flat end of a spudger to pry both antenna connectors up off their sockets on the motherboard.
  14. PlayStation 3 Slim Antennas Replacement: passo 14, imagem 1 %32 PlayStation 3 Slim Antennas Replacement: passo 14, imagem 2 %32
    • Lift the antennas off their plastic positioning posts and remove them from the lower case, minding their cables that may get caught.
Conclusão
18 outras pessoas executaram este guia.
6 comentários
Do you guys have parts for PlayStation 3 Slim Antennas I want to now I can buy some from you guys
Edwin gomez - Responder
Hi! i'm facing this 8002f1f9 error code and my ps3 is slim can you please help me out or suggest some troubleshootings.
Rafiq Gamrai - Responder
Network adapter or joystick connection problem
Hyperion -
Which color is the wifi and which is the bluetooth? I haven’t tested the wifi on the system yet, but the controllers are not connecting so I think I have to replace just the bluetooth part.
optimusp517 - Responder
A year or so ago I noticed my controller wasn't working unless plugged in. I thought it might just be failed battery over the years, but it worked when plugged in, so it was only a minor inconvenience. Later, I realized WiFi wasn't working either, so I thought maybe an update would fix things… plugged into wired network to update system.
DO NOT UPDATE YOUR SYSTEM IF EXPERIENCING WIFI OR BLUETOOTH CONNECTIVITY ISSUES!
Now stuck in a boot loop where the update tries and fails to install. I can't get back into my system to backup and transfer my data, so I'm stuck looking for a solution to either fix my system or transfer to a replacement, but even for an estimated repair cost of $120, Sony support said their first attempted fix action will be to factory reset the system.
Anybody have any advice?
Sony, why would you allow a firmware update to begin install without first running a basic hardware check? Then, why wouldn't you allow some recovery option for a failed update?
Guess I've learned to always backup my stuff.
Matthew Eskuchen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 66
Últimos 30 dias: 328
Duração total: 49,328
