Introdução
Use this guide to replace the AC socket and its cables connected to the power supply.
O que você precisa
Turn the PS3 over and lay it on its backside.
Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
Lift the AC inlet cables straight upward to remove the AC inlet from the lower case.
23 outras pessoas executaram este guia.
