Ir para o conteúdo principal
PlayStation 3 Slim Laser Unit (Laser and Mechanism) Replacement
O que você precisa
Vídeo de Apresentação
  1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): passo 1, imagem 1 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): passo 1, imagem 2 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): passo 1, imagem 3 %32
    • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 2, imagem 1 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 2, imagem 2 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 2, imagem 3 %32
    • Remove Power Supply.
  3. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 3, imagem 1 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 3, imagem 2 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 3, imagem 3 %32
    • Separate cables, unscrew the screw and remove the Blu Ray drive.
  4. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 4, imagem 1 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 4, imagem 2 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 4, imagem 3 %32
    • Disassemble the upper metal shield.
  5. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 5, imagem 1 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 5, imagem 2 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 5, imagem 3 %32
    • Remove the two very small phillips screws in each lower corner referenced by the red circles.
  6. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 6, imagem 1 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 6, imagem 2 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 6, imagem 3 %32
    • Be careful with flex cables.
  7. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 7, imagem 1 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 7, imagem 2 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 7, imagem 3 %32
    • Now you can remove the Laser Deck.
  8. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 8, imagem 1 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 8, imagem 2 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 8, imagem 3 %32
    • Transfer two flex cables and 2x rubbers.
  9. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 9, imagem 1 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 9, imagem 2 %32 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 9, imagem 3 %32
    • You can test the console before full assembling.
Conclusão
16 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
187.961 Reputação
330 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
311 Membros
1.196 Guias de autoria
Um comentário
Do you know what the part number is for the deck? I don’t want to buy the wrong one. Thanks.
Edmond Charrette - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 61
Últimos 30 dias: 293
Duração total: 25,061
