Ir para o conteúdo principal
PlayStation 3 Slim (CECH-300X) Fan system Replacement
O que você precisa
Vídeo de Apresentação
  1. PlayStation 3 Slim (CECH-300X) Fan system Replacement, Fan system: passo 1, imagem 1 %32 PlayStation 3 Slim (CECH-300X) Fan system Replacement, Fan system: passo 1, imagem 2 %32 PlayStation 3 Slim (CECH-300X) Fan system Replacement, Fan system: passo 1, imagem 3 %32
    • Disconnect the fan cable and remove the nine screws from the bottom side.
  2. PlayStation 3 Slim (CECH-300X) Fan system Replacement: passo 2, imagem 1 %32 PlayStation 3 Slim (CECH-300X) Fan system Replacement: passo 2, imagem 2 %32 PlayStation 3 Slim (CECH-300X) Fan system Replacement: passo 2, imagem 3 %32
    • Remove the two heat sink clamps and bottom shield, then gently separate the motherboard off the top shield.
  3. PlayStation 3 Slim (CECH-300X) Fan system Replacement: passo 3, imagem 1 %32 PlayStation 3 Slim (CECH-300X) Fan system Replacement: passo 3, imagem 2 %32 PlayStation 3 Slim (CECH-300X) Fan system Replacement: passo 3, imagem 3 %32
    • Remove the four Phillips screws and lift the top shield.
  4. PlayStation 3 Slim (CECH-300X) Fan system Replacement: passo 4, imagem 1 %32 PlayStation 3 Slim (CECH-300X) Fan system Replacement: passo 4, imagem 2 %32 PlayStation 3 Slim (CECH-300X) Fan system Replacement: passo 4, imagem 3 %32
    • That's all.
Conclusão
9 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
187.961 Reputação
330 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
311 Membros
1.196 Guias de autoria
2 comentários
Awesome guide. Thank you so much. I did it, but now I just wonder what that white stuff was when I removed the motherboard. I think it's that thermal stuff people have been talking about and I suppose I have to replace that. I also hope that it's the fan that is what's causing my PS3 to say that it's overheating and shut off. I'm so glad you guys posted this. Great job. I rather do it myself than pay Sony an arm and a leg. Cheers!
chetacheez - Responder
This is CPU / GPU thermal paste / compound. I recommend you Arctic MX-2, MX-4. It is very good and not expensive.
ZFix -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 43
Últimos 30 dias: 259
Duração total: 14,026
