Ir para o conteúdo principal
Introdução
Use this guide to replace a broken control board.
  1. Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3. The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
    Fake repair. Real fault: How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
    Player - Responder
  2. Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
    Player - Responder
  3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
    Player - Responder
  4. Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
    That small metal bracket/socket set up looks completely different in the ps3 I'm working on. Model: CECHK01.
    Any suggestions?
    Marcus - Responder
    different in mine too, Model: CECHP01
    Link Adrian - Responder
    mine does not have one at all
    ian.downard01 - Responder
    1How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
    Player - Responder
  5. Remove the following seven screws:
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
    2 more smaller screws (don't know what size...small) just below the top middle screw and top right screw (in the picture). Look for the arrows...
    E Goo - Responder
    can confirm, might be the backwards compatibles only
    Jordan Giese -
    after you remove the screws, you may have to push a tab to take the cover off if you meet resistance on one side of the cover. Here is a link to a video that explains it, saved me lots of trouble:
    http://youtu.be/jZgekNsRB-A?t=1m54s
    ericksi33 - Responder
    Thanks @ericksi33, this really helped me out.
    hogurt -
    1st attempt, fan loud. Ps3 lasted about 2 wks. 2nd attempt noticed very poor contact between heatsink & cpu,gpu when taking it apart. Research - Found a better way to apply thermal past. I personally disapprove of guide on this. A small bit about the size of a grain of rice in center of cpu is plenty. Clamp the heat sinks back on. Then take it apart & check contact area. Thermal paste should have spread to about the size of a quarter.(more is better. Less then a nickel size is poor contact) possibly weak clamps. Carefully applied pressure onto the cpu & gpu, pressing them into the heatsinks before clamping heatsink clamps on. Achieved greater then quarter sized thermal past spread. Fan silent in comparison & ps3 lasted about a yr. Rarely did I ever hear the fan go to high and get loud after that. About to begin my third fix on this same ps3. One of the first 80g backwards compatible. other then those notes and that this guide was for a different model ps3 (minor differences) I liked this guide. easy to follow.
    brettgomes - Responder
    Although the battery is described as proprietary, it looks like it is the common CR2032 lithium coin battery that is used in calculators and some computers. I haven't had to replace mine but I suspect under the heatshrink cover is a battery holder which will allow the coin battery to be removed and replaced. Then wrap with electrical tape and reinstall.
    RickP - Responder
    I tried this with the heatgun and it ruined my PS3. The CPU and GPU are NOW RUINED!!! It did not work for and made things worst!!! I sent it to a place to get reballed and they said the HEATGUN had overheated my processor and killed them!!! So think twice about doing this. Just because it is already broken, DON'T THINK YOU CAN'T MAKE IT WORST!
    georgehollyoh - Responder
    Why would you try it with a heat gun, no were is it mentioned to do that
    Phillip Pereira -
    There are 2 additional screws to remove , front center and front left , just behind the already marked screws.
    mikentc90 - Responder
    As mentioned and I’ll add so detail too. If you have a model with the card readers there are two more small screws that also need to be removed before moving on to the next step.
    screech - Responder
    2How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
    Player - Responder
  6. Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing.
    Disconnect the memory card ribbon cable.
    Tobias Stockmann - Responder
    The top would hardly budge on the left back corner and was stuck on the right back corner. There is a plastic hook that needs to be unfastened to lift the top off. It is located in a hole on the top back corner on the right hand side, so the corner straight across the on off button. Just gently push the plastic hook a bit front the rear of the machine with a spudger. It gives easily and the top will be free to lift off after that.
    cornellg - Responder
    Some more details here as well.
    The newer model without SACD support appears to have added that clip to the back right that needs to be pressed to release the top shell.
    If equipped with the card reader you can either have to disconnect the ribbon cable or unclip the reader from the top shell after lifting it up to get finger or tool in there to push clip to side and release reader from top shell. Note: if you failed to remove the card reader screws in the previous step these clips can break.
    screech - Responder
    The original 60GB with the CF card reader on the front has a button protruding out. This will make it difficult to remove the top. You need to unscrew the memory card reader so it can come out easily.
    Brian Caines - Responder
  7. Use your fingernail to flip up the retaining flap on the control board ribbon cable socket. Be sure you are prying up on the retaining flap, not the socket itself.
    • Use your fingernail to flip up the retaining flap on the control board ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the control board ribbon cable out of its socket.
  8. Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
  9. Remove the control board from the lower case.
    • Remove the control board from the lower case.
Conclusão
15 outras pessoas concluíram este guia.
2 comentários
I don't have the same ps3 as in the tutorial and my control board is broken. What can i do now?
McGarvey - Responder
Could anyone tell me if they would have the connection pin of this board, as I would like to fit it into a motherboard.
Allan Fabian Santos Souza - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 63
Duração total: 45,966
