Ir para o conteúdo principal
PlayStation 3 Blu-Ray Drive Replacement
O que você precisa
  1. PlayStation 3 Blu-Ray Drive Replacement, Smart Plate: passo 1, imagem 1 %32 PlayStation 3 Blu-Ray Drive Replacement, Smart Plate: passo 1, imagem 2 %32
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
    Fake repair. Real fault: How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
    Player - Responder
  2. PlayStation 3 Blu-Ray Drive Replacement: passo 2, imagem 1 %32
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
    Player - Responder
    I need a tork screw bracket / holder A/E/B/E01- MG and security torx screw for a CECH-AO1 do u guys sell these?
    vuhx - Responder
  3. PlayStation 3 Blu-Ray Drive Replacement: passo 3, imagem 1 %32 PlayStation 3 Blu-Ray Drive Replacement: passo 3, imagem 2 %32 PlayStation 3 Blu-Ray Drive Replacement: passo 3, imagem 3 %32
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
    Player - Responder
  4. PlayStation 3 Blu-Ray Drive Replacement: passo 4, imagem 1 %32
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
    That small metal bracket/socket set up looks completely different in the ps3 I'm working on. Model: CECHK01.
    Any suggestions?
    Marcus - Responder
    different in mine too, Model: CECHP01
    Link Adrian - Responder
    mine does not have one at all
    ian.downard01 - Responder
    1How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
    Player - Responder
    Did not find in my CECHH01
    Philippe Morin - Responder
    I don’t have this bracket, where I can get it ?
    Paul Bidny - Responder
  5. PlayStation 3 Blu-Ray Drive Replacement, Top Cover: passo 5, imagem 1 %32
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
    2 more smaller screws (don't know what size...small) just below the top middle screw and top right screw (in the picture). Look for the arrows...
    E Goo - Responder
    can confirm, might be the backwards compatibles only
    Jordan Giese -
    This usually isn't needed as you can additionally unclip the card reader by pushing the tabs out while lifting the top, They are located at the bottom of the screw holes with the arrows pointing at them
    Kenneth Beerman -
    after you remove the screws, you may have to push a tab to take the cover off if you meet resistance on one side of the cover. Here is a link to a video that explains it, saved me lots of trouble:
    http://youtu.be/jZgekNsRB-A?t=1m54s
    ericksi33 - Responder
    Thanks @ericksi33, this really helped me out.
    hogurt -
    1st attempt, fan loud. Ps3 lasted about 2 wks. 2nd attempt noticed very poor contact between heatsink & cpu,gpu when taking it apart. Research - Found a better way to apply thermal past. I personally disapprove of guide on this. A small bit about the size of a grain of rice in center of cpu is plenty. Clamp the heat sinks back on. Then take it apart & check contact area. Thermal paste should have spread to about the size of a quarter.(more is better. Less then a nickel size is poor contact) possibly weak clamps. Carefully applied pressure onto the cpu & gpu, pressing them into the heatsinks before clamping heatsink clamps on. Achieved greater then quarter sized thermal past spread. Fan silent in comparison & ps3 lasted about a yr. Rarely did I ever hear the fan go to high and get loud after that. About to begin my third fix on this same ps3. One of the first 80g backwards compatible. other then those notes and that this guide was for a different model ps3 (minor differences) I liked this guide. easy to follow.
    brettgomes - Responder
    Although the battery is described as proprietary, it looks like it is the common CR2032 lithium coin battery that is used in calculators and some computers. I haven't had to replace mine but I suspect under the heatshrink cover is a battery holder which will allow the coin battery to be removed and replaced. Then wrap with electrical tape and reinstall.
    RickP - Responder
    I tried this with the heatgun and it ruined my PS3. The CPU and GPU are NOW RUINED!!! It did not work for and made things worst!!! I sent it to a place to get reballed and they said the HEATGUN had overheated my processor and killed them!!! So think twice about doing this. Just because it is already broken, DON'T THINK YOU CAN'T MAKE IT WORST!
    georgehollyoh - Responder
    Why would you try it with a heat gun, no were is it mentioned to do that
    Phillip Pereira -
    There are 2 additional screws to remove , front center and front left , just behind the already marked screws.
    mikentc90 - Responder
    As mentioned and I’ll add so detail too. If you have a model with the card readers there are two more small screws that also need to be removed before moving on to the next step.
    screech - Responder
    2How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
    Player - Responder
    I felt more comfortable with #2 screwdrivers.
  6. PlayStation 3 Blu-Ray Drive Replacement: passo 6, imagem 1 %32
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
    Disconnect the memory card ribbon cable.
    Tobias Stockmann - Responder
    The top would hardly budge on the left back corner and was stuck on the right back corner. There is a plastic hook that needs to be unfastened to lift the top off. It is located in a hole on the top back corner on the right hand side, so the corner straight across the on off button. Just gently push the plastic hook a bit front the rear of the machine with a spudger. It gives easily and the top will be free to lift off after that.
    cornellg - Responder
    I can confirm on CECHH01.
    Philippe Morin -
    Some more details here as well.
    The newer model without SACD support appears to have added that clip to the back right that needs to be pressed to release the top shell.
    If equipped with the card reader you can either have to disconnect the ribbon cable or unclip the reader from the top shell after lifting it up to get finger or tool in there to push clip to side and release reader from top shell. Note: if you failed to remove the card reader screws in the previous step these clips can break.
    screech - Responder
    The original 60GB with the CF card reader on the front has a button protruding out. This will make it difficult to remove the top. You need to unscrew the memory card reader so it can come out easily.
    Brian Caines - Responder
    Wow, this needs more attention. This isn't explained in any disassembly guide I've seen. You also need to be cognizant of the card reader cable when you're lifting off the lid.
    SolidSonicTH -
    I didn't have trouble during disassembly, but reassembly was tough. I loosened the card reader screws by 1 turn and used a small gauge wire to lasso the button and ran it through the CF hole.
    Carl Garner -
  7. PlayStation 3 Blu-Ray Drive Replacement, Blu-ray Disc Drive: passo 7, imagem 1 %32
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
    I would add… “Be careful taking these type of connectors apart” …. its easy to pull the entire thing off the motherboard and rip pads !
    The pulled pads can be replaced but its extra work you don’t need :-) and requires equipment and skill to do and cold require jumper wires.
    asears - Responder
    Pull the cables gently, the plug will come out of the socket. The plug is encased by the socket.
    A K - Responder
    That’s also what I did.
    Philippe Morin -
    My PS3 is the CECHL01 and I had to remove the PSU to get to the disk drive ribbon cable.
    Benjamin Burden - Responder
    I mistakenly ripped the whole thing out... I do not know where to begin on repairing it.
    Tom Gillis - Responder
  8. PlayStation 3 Blu-Ray Drive Replacement: passo 8, imagem 1 %32
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
  9. PlayStation 3 Blu-Ray Drive Replacement: passo 9, imagem 1 %32 PlayStation 3 Blu-Ray Drive Replacement: passo 9, imagem 2 %32 PlayStation 3 Blu-Ray Drive Replacement: passo 9, imagem 3 %32
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
    Not all systems look like this, some have tape instead of the flap.
    gatewaynomad - Responder
    Every system that I have seen has had the ZIF connector, while some had tape over the connection as well. If your connectors are taped, be sure to remove the tape, then proceed with undoing the ZIF connector.
    Brett Hartt -
    The version 2 systems baseboard PCB started switching to the new narrow 24 pin ZIF header/ribbon and Blu-Ray drive connection.
    You should not attempt to detach the taped ribbon cable from the drive end first as described above for the older wide 60 pin ribbons. You must remove the drive and ribbon as one unit to protect the fragile ZIF sockets.
    The slimmer fragile ribbon is taped to the drive housing to afford a more secure ZIF connection. The opposite base connection is slightly under the PSU.
    continued
    shadetree - Responder
    From continued
    One should firstly remove the PSU: Disconnect the drive power cable as described above. Unscrew the 5 (3-P1 2-P2) PSU mounting screws. Now leaving the power cables attached, lift the PSU off the power baseboard PCB pins and move over slightly to access the baseboard drive cable end ZIF. Release the ZIF latch and slide the entire (drive and ribbon) strait away from the baseboard ZIF to disconnect.
    After the complete drive/ribbon removal, you can carefully remove the restraining tape on the bottom of the drive to release the ribbon ZIF, then remove the 24 pin ribbon from the drive logic PCB.
    Install in reverse order making sure to add new tape to secure the ribbon to the drive.
    I needed to remove the PSO completely to reach the baseboard drive cable end ZIF. To do that disconnect the power and data (I assume) cables and then pull the unit straight up. To longish prongs are heading straight up into it from the baseboard and it is a bit tight, so gently pull until it's clear.
    cornellg -
    If you are replacing the Blu-ray drive, you must use the same daughterboard that came with your PlayStation 3. The daughterboard is paired to the motherboard, and the Blu-ray drive will not work with a different board. -------------- I understand however my daughterboard is not on the bottom of the blu-ray drive it must be on the inside. Is there any advice out there on how I go about doing this as I am not sure what I am doing???? If someone could post a link or any tips it would be greatly appreciated.
    jimmy - Responder
    When I received my new drive there was a sheet that said you could keep the old boards but you have to 'flash' them with the ps3's digital information. Currently trying to figure out how.....
    Cheffy -
    My CECHH01 has its blu-ray drive encased in a shield plate. Only one ribbon cable is visible. (The one we have to disconnect). Mine had some tape over it.
    Also, I used a spudger instead of my nails.
  10. PlayStation 3 Blu-Ray Drive Replacement, Blu-Ray Drive: passo 10, imagem 1 %32 PlayStation 3 Blu-Ray Drive Replacement, Blu-Ray Drive: passo 10, imagem 2 %32
    • Using your fingernail, lift the flap on the ZIF connector holding the Blu-ray lens motor cable to the Blu-ray control daughterboard.
    • Pull the ribbon cable straight away from its socket on the daughterboard.
  11. PlayStation 3 Blu-Ray Drive Replacement: passo 11, imagem 1 %32 PlayStation 3 Blu-Ray Drive Replacement: passo 11, imagem 2 %32
    • Using your fingernail, lift the flap on the ZIF connector holding the Blu-ray lens Data cable to the Blu-ray control daughterboard.
  12. PlayStation 3 Blu-Ray Drive Replacement: passo 12, imagem 1 %32 PlayStation 3 Blu-Ray Drive Replacement: passo 12, imagem 2 %32
    • Using your fingernail, lift the flap on the ZIF connector holding the Blu-ray drive motor cable to the Blu-ray control daughterboard.
  13. PlayStation 3 Blu-Ray Drive Replacement: passo 13, imagem 1 %32 PlayStation 3 Blu-Ray Drive Replacement: passo 13, imagem 2 %32
    • Using your fingernail, lift the flap on the ZIF connector holding the Blu-ray IR sensor cable to the Blu-ray control daughterboard.
  14. PlayStation 3 Blu-Ray Drive Replacement: passo 14, imagem 1 %32 PlayStation 3 Blu-Ray Drive Replacement: passo 14, imagem 2 %32
    • Remove the five 8.4mm phillips screws securing the Blu-ray control board to the Blu-ray drive.
    • Be sure to also remove the metal ground springs from under the screws in the corners.
  15. PlayStation 3 Blu-Ray Drive Replacement: passo 15, imagem 1 %32 PlayStation 3 Blu-Ray Drive Replacement: passo 15, imagem 2 %32
    • Carefully lift the daughterboard from the rear edge.
    • Slide the daughterboard out from under the top case.
    • Do not try to remove the daughterboard yet, as it is still connected by a cable on the underside of the board.
    Gibt es ne möglichkeit die neue platine anzulernen
    Ultrageil Official - Responder
  16. PlayStation 3 Blu-Ray Drive Replacement: passo 16, imagem 1 %32 PlayStation 3 Blu-Ray Drive Replacement: passo 16, imagem 2 %32
    • Carefully turn the daughterboard over, making sure to not tear the attached cable.
    • Pull the IR Sensor cable straight away from its socket on the board.
    • Be sure that you are not pulling on the cables as you remove the plug from its socket.
    • Blu-Ray drive remains.
    • If you are replacing the Blu-ray drive, you must use the same daughterboard that came with your PlayStation 3. The daughterboard is paired to the motherboard, and the Blu-ray drive will not work with a different board.
Conclusão
83 outras pessoas executaram este guia.
Brett Hartt
Membro desde: 04/12/10
127.897 Reputação
Autoria de 143 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
5 comentários
Is there a thermal pad replacement for the bond between the Optical Drive and the metal housing of around the motherboard? I can play Borderlands for hours, but if I use a disc based game or one with more intensive graphics the overheat light comes on. I’m thinking of reapplying the thermal paste with the squish method as well. Already by replacing the thermal pads (some were missing or just like clay) has reduced the fan noise. Any suggestions? The thermal pad currently is also claylike.
Canis Lupis - Responder
The IR sensor cable broke ; how to fix it?
Ginny - Responder
Id probably just buy a new disc drive for the ps3 fat, you can find them on sites like amazon and eBay for reasonable prices
John Doe -
I have a CECHC04 that does not accept discs. If i replace the BD drive with another one from a CECHC03 will it work, or do i have to keep my original daughterboard as well? What if my problem is the daughterboard?
Charalambos Hanni - Responder
I got everything re hooked up but when I insert my disc , it won't suck it in. is that normal or do I have my wires crossed?
Kelly Anaya - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 20
Últimos 7 dias: 112
Últimos 30 dias: 485
Duração total: 104,295
