Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Replace your PlayStation 2's scratched-up or worn out top cover.
  1. Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards. Use the flat edge of a metal spudger to pry the eight flat screw covers out. Remove the following eight screws securing the top cover to the bottom case:
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
  2. Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. Flip the PlayStation 2 back to its original upside position. Lift the top cover off the bottom case.
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the bottom case.
Conclusão
18 outras pessoas concluíram este guia.
jwyoung
Membro desde: 04/11/2009
2.186 Reputação
5 Guias de autoria
Equipe
Cal Poly, Team 19-1, Maness Fall 2009 Membro de Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 Membros
33 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 100
Duração total: 13,398
