Introdução
This guide will walk you through step-by-step on how to properly remove and install the motherboard in the PlayStation 2 Slimline.
O que você precisa
Passo 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
Cuidado: as etapas de 1 a 7 são provenientes de um guia marcado como em andamento.
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
Passo 8 IR Sensor
Cuidado: a etapa 8 é proveniente de um guia marcado como em andamento.
Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
Locate the fan component of the motherboard of the PS2.
With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
Passo 14 Optical Drive
Cuidado: as etapas de 14 a 18 são provenientes de um guia marcado como em andamento.
Locate the optical drive on the motherboard.
What you see in this picture is the electronic components found in the PS2. We are now going to remove the top metal casing found on top of the motherboard.
12 outras pessoas executaram este guia.
