Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to walk through a step-by-step process on how to properly replace a broken fan in the PlayStation 2 Slimline SCPH-7500x . The fan’s purpose is to keep the other components in the PlayStation from overheating. You should hear the fan run intermittently while the PlayStation is on. If you do not hear a fan or the system is overheating try following this guide to replace it.
O que você precisa
Passo 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
Cuidado: as etapas de 1 a 7 são provenientes de um guia marcado como em andamento.
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
Locate the fan component of the motherboard of the PS2.
With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
4 outras pessoas executaram este guia.
