Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will walk you through step-by-step on how to properly remove and install the clock battery in the PlayStation 2 Slimline.
O que você precisa
Passo 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
Cuidado: as etapas de 1 a 7 são provenientes de um guia marcado como em andamento.
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
8 outras pessoas executaram este guia.
Um comentário
These instructions take for granted how the battery itself should be replaced. I imagine you reconnect the contact with the red wire to the positive side of the CR2032 battery and the contact for the black wire to the negative and wrap electrical tape around the entire thing BEFORE reconnecting it and then following these instructions in reverse order.
