Ir para o conteúdo principal
PlayStation 2 Slimline Optical Drive Replacement
O que você precisa
  1. PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: passo 1, imagem 2 %32 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: passo 1, imagem 3 %32
    • Remove the rubber feet on two of the screw covers on the bottom of the console.
    • Remove the screw covers and the screws themselves.
    • Caution: One of the screws is underneath the "Do not void" seal
  2. PlayStation 2 Slimline Optical Drive Replacement: passo 2, imagem 1 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 2, imagem 2 %32
    • If all screws are removed.
    • Use a metal spunger to open the chassis
  3. PlayStation 2 Slimline Optical Drive Replacement: passo 3, imagem 1 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 3, imagem 2 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 3, imagem 3 %32
    • Slip the three cables out of the sockets.
    • Use a PH01 screwdriver to remove the four screws securing the optical drive
    • Lift up the optical drive and remove the duct tape under the flex cable.
    • Now the optical drive is free and ready for replacement
Conclusão
16 outras pessoas executaram este guia.
tlroesner
Membro desde: 05/13/12
1.864 Reputação
Autoria de 4 guias
3 comentários
How is it that this guide says difficult and the other PS2 drive replacement on here says easy?
Mark - Responder
it really depends on your level of skill/experience.
Damien Simons -
How many different versions of drive is there for the slim model? When you go to replace it, do you just compare the model number on the laser?
Trevor V - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 25
Últimos 30 dias: 102
Duração total: 22,125
