Ir para o conteúdo principal
PlayStation 2 Slimline Optical Drive Replacement
O que você precisa
  1. PlayStation 2 Slimline Optical Drive Replacement, Outer Shell: passo 1, imagem 1 %32
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline Optical Drive Replacement: passo 2, imagem 1 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 2, imagem 2 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 2, imagem 3 %32
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline Optical Drive Replacement: passo 3, imagem 1 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 3, imagem 2 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 3, imagem 3 %32
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline Optical Drive Replacement: passo 4, imagem 1 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 4, imagem 2 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 4, imagem 3 %32
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: passo 5, imagem 1 %32 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: passo 5, imagem 2 %32
    • Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard.
  6. PlayStation 2 Slimline Optical Drive Replacement: passo 6, imagem 1 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 6, imagem 2 %32
    • Remove the four 4.0 mm screws using a #1 Phillips screwdriver.
  7. PlayStation 2 Slimline Optical Drive Replacement: passo 7, imagem 1 %32
    • Locate the three ribbon cables connecting the optical drive to the motherboard.
  8. PlayStation 2 Slimline Optical Drive Replacement: passo 8, imagem 1 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 8, imagem 2 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 8, imagem 3 %32
    • Gently detach the ribbon cables from the motherboard using a pair of tweezers.
    • Note: The ribbon cable in the center must be unlocked by lifting up the black tab. Remember to push the tab down upon re-installation to secure the cable.
    • Caution: Always remove ribbon cables by the plastic handles located on each end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  9. PlayStation 2 Slimline Optical Drive Replacement: passo 9, imagem 1 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 9, imagem 2 %32 PlayStation 2 Slimline Optical Drive Replacement: passo 9, imagem 3 %32
    • Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive.
    Be really careful when dealing with the orange ribbon cable attached to the optical lens, as it is glued on the metal surface underneath it. From normal usage months or years, and the optical lens natural movement, this ribbon might lose some glue and start lifting upwards, sometimes even touching the CD surface. This could start scratching your games to an unplayable extent. Reapply glue if needed.
    Americo Santos Oliveira - Responder
    You don't necessarily need to remove the ribbon cable from the shield. After you detached the cable from the motherboard, flip the optical drive and detach the other end of the cable.
    Vincenzo Quinci - Responder
Conclusão
24 outras pessoas executaram este guia.
Thomas Sullivan
Membro desde: 10/23/13
3.927 Reputação
Autoria de 6 guias
7 comentários
انا أريد للغة عربية
Muammar lmgaroush - Responder
you also must disconnect the ribbon cable from the laser assembly by flipping back the little brown lever and removing the cable. This frees the assembly from the rest of the console. To actually replace the drive, you need to move the lens away from the disc hub by gently turning the worm gear. Flip the new assembly over and connect the brown ribbon that is glued to the metal shield. DO NOT REMOVE THE GLUED RIBBON UNLESS YOU INTEND TO REPLACE IT. After that one is connected, you can slowly flip the assembly and rest is in place. Connect the other ribbons to their respective connectors. Return all the screws to their positions and tighten so they are firm. Don’t go overboard screwing them back in.
Rusty Shackleford - Responder
Hello is the optical drive from my ps2 70004 compatible in my ps2 slim 75001?
Jorick Earl Bastian - Responder
I don't see any reason why it shouldn't be.
LOLMAN 9538 (LOLMAN9538) -
This is a great instructional aside from one thing, if you don’t not have the tape/glue for the ribbon cable that goes under the assembly, do not remove that ribbon cable from the shell. just disconnect it from the assembly, and put it in the new assembly. I wish I had read the comments before I did this myself. Please add this to the notes for the instructional. Now one of my games are ruined, and I have to buy a new one.
Noah L - Responder
Another thing to note when replacing the optical reader: all replacement readers will have a solder blob attaching the ribbon cable to the lens assembly. This is mainly to prevent static buildup during delivery, and it must be removed before installation.
LOLMAN 9538 (LOLMAN9538) - Responder
Is the ps2 90006 optical drive compatible with ps2 series 75000?
Zoukambada - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 109
Últimos 30 dias: 441
Duração total: 24,286
