Ir para o conteúdo principal
PlayStation 2 Slimline IR Sensor Replacement
O que você precisa
  1. PlayStation 2 Slimline IR Sensor Replacement, Outer Shell: passo 1, imagem 1 %32
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline IR Sensor Replacement: passo 2, imagem 1 %32 PlayStation 2 Slimline IR Sensor Replacement: passo 2, imagem 2 %32 PlayStation 2 Slimline IR Sensor Replacement: passo 2, imagem 3 %32
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline IR Sensor Replacement: passo 3, imagem 1 %32 PlayStation 2 Slimline IR Sensor Replacement: passo 3, imagem 2 %32 PlayStation 2 Slimline IR Sensor Replacement: passo 3, imagem 3 %32
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline IR Sensor Replacement: passo 4, imagem 1 %32 PlayStation 2 Slimline IR Sensor Replacement: passo 4, imagem 2 %32 PlayStation 2 Slimline IR Sensor Replacement: passo 4, imagem 3 %32
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline IR Sensor Replacement, IR Sensor: passo 5, imagem 1 %32
    • Locate the IR sensor at the front, right corner of the unit.
  6. PlayStation 2 Slimline IR Sensor Replacement: passo 6, imagem 1 %32
    • Gently detach the ribbon cable connecting the IR sensor to the motherboard.
    • Caution: Always remove ribbon cables by the plastic handles located on either end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  7. PlayStation 2 Slimline IR Sensor Replacement: passo 7, imagem 1 %32
    • Gently lift and remove the IR Sensor from its designated slot.
Conclusão
8 outras pessoas executaram este guia.
Thomas Sullivan
Membro desde: 10/23/13
3.927 Reputação
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 100
Duração total: 6,830
