Ir para o conteúdo principal
PlayStation 2 Slimline Fan Replacement
O que você precisa
  1. PlayStation 2 Slimline Fan Replacement, Outer Shell: passo 1, imagem 1 %32
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline Fan Replacement: passo 2, imagem 1 %32 PlayStation 2 Slimline Fan Replacement: passo 2, imagem 2 %32 PlayStation 2 Slimline Fan Replacement: passo 2, imagem 3 %32
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline Fan Replacement: passo 3, imagem 1 %32 PlayStation 2 Slimline Fan Replacement: passo 3, imagem 2 %32 PlayStation 2 Slimline Fan Replacement: passo 3, imagem 3 %32
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline Fan Replacement: passo 4, imagem 1 %32 PlayStation 2 Slimline Fan Replacement: passo 4, imagem 2 %32 PlayStation 2 Slimline Fan Replacement: passo 4, imagem 3 %32
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline Fan Replacement, Fan: passo 5, imagem 1 %32 PlayStation 2 Slimline Fan Replacement, Fan: passo 5, imagem 2 %32
    • Locate the fan at the front, left section of the unit.
  6. PlayStation 2 Slimline Fan Replacement: passo 6, imagem 1 %32 PlayStation 2 Slimline Fan Replacement: passo 6, imagem 2 %32
    • Peel off the sticker holding the power cords to the unit.
  7. PlayStation 2 Slimline Fan Replacement: passo 7, imagem 1 %32 PlayStation 2 Slimline Fan Replacement: passo 7, imagem 2 %32
    • Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
  8. PlayStation 2 Slimline Fan Replacement: passo 8, imagem 1 %32 PlayStation 2 Slimline Fan Replacement: passo 8, imagem 2 %32 PlayStation 2 Slimline Fan Replacement: passo 8, imagem 3 %32
    • Remove all three 1.6 mm screws fastening the fan to the unit using a #1 Phillips screwdriver.
    • Gently lift and remove the fan from its compartment.
Conclusão
10 outras pessoas executaram este guia.
Thomas Sullivan
Membro desde: 10/23/13
3.927 Reputação
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 104
Duração total: 8,334
