Ir para o conteúdo principal
PlayStation 2 Slimline CMOS Battery Replacement
O que você precisa
  1. PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: passo 1, imagem 1 %32 PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: passo 1, imagem 2 %32 PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: passo 1, imagem 3 %32
    • Remove all five screws on the downside of the PS2 Slimline
    • Remove the "Do not void" seal carefully, underneath is the fifth screw located.
  2. PlayStation 2 Slimline CMOS Battery Replacement: passo 2, imagem 1 %32 PlayStation 2 Slimline CMOS Battery Replacement: passo 2, imagem 2 %32
    • Take a metal spudger and open the chassis
  3. PlayStation 2 Slimline CMOS Battery Replacement: passo 3, imagem 1 %32 PlayStation 2 Slimline CMOS Battery Replacement: passo 3, imagem 2 %32 PlayStation 2 Slimline CMOS Battery Replacement: passo 3, imagem 3 %32
    • Locate the battery on the motherboard
    • Use a metal spudger to pull it up
    • Pull the cable and the battery is removed, ready to replace
    Hey, thank you. Do you know the name of the connector? There are many connectors for cmos batteries out there. Thank you in advance.
    protux - Responder
Conclusão
5 outras pessoas executaram este guia.
tlroesner
Membro desde: 05/13/12
1.864 Reputação
Autoria de 4 guias
3 comentários
why would i need to do this?
Dimitrios Frantzis - Responder
To prior poster, you will not be able to effectively play certain types of games once the server is shut off by Sony.
Joe W. - Responder
What do I replace the battery with? Can I re-apply the rubber casing of the original battery onto a new 2032 or what?
Jarad Webb - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 40
Duração total: 10,919
