Ir para o conteúdo principal
PlayStation 2 Slimline CMOS Battery Replacement
O que você precisa
  1. PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: passo 1, imagem 1 %32 PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: passo 1, imagem 2 %32 PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: passo 1, imagem 3 %32
    • Remove all five screws on the downside of the PS2 Slimline
    • Remove the "Do not void" seal carefully, underneath is the fifth screw located.
  2. PlayStation 2 Slimline CMOS Battery Replacement: passo 2, imagem 1 %32 PlayStation 2 Slimline CMOS Battery Replacement: passo 2, imagem 2 %32
    • Take a metal spudger and open the chassis
  3. PlayStation 2 Slimline CMOS Battery Replacement: passo 3, imagem 1 %32 PlayStation 2 Slimline CMOS Battery Replacement: passo 3, imagem 2 %32 PlayStation 2 Slimline CMOS Battery Replacement: passo 3, imagem 3 %32
    • Locate the battery on the motherboard
    • Use a metal spudger to pull it up
    • Pull the cable and the battery is removed, ready to replace
Conclusão
5 outras pessoas executaram este guia.
tlroesner
Membro desde: 05/13/12
1.864 Reputação
Autoria de 4 guias
3 comentários
why would i need to do this?
Dimitrios Frantzis - Responder
To prior poster, you will not be able to effectively play certain types of games once the server is shut off by Sony.
Joe W. - Responder
What do I replace the battery with? Can I re-apply the rubber casing of the original battery onto a new 2032 or what?
Jarad Webb - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 40
Duração total: 10,915
