Introdução
The "Disc Read Error" is one of the most common, and possibly the most frustrating error you might encounter.
The problem occurs because dust or debris has accumulated on the lens. Luckily, it is easy to fix and takes a few short and simple steps!
Ferramentas
Peças
Nenhum componente especificado.
Use the flat edge of a metal spudger to pry the eight flat screw covers out.
Remove the following eight screws securing the top cover to the bottom case:
Four 55.4 mm Philips screws
Four 18.0 mm Phillips screws
Remove the four 6.4 mm Phillips screws securing the top lid of the optical disc drive.
Lift and remove the lid from the optical disc drive.
50 outras pessoas concluíram este guia.
9 comentários
I've tried the steps mentioned above to no avail. The problem persist. Anything else i can do besides purchasing another console? Sentimental value.Thank you.
What I'm gonna try and do is take a laser from a PC DVD burner tray and see if I reads things. It's a long shot but you can't break what's already broken ehh. I'll let you know what happens. And if it works I will write the proper tutorial for it:)
HOw to use a lens cleaner dvd in Ps2
please answer my problem
hi i have a problem with my ps2. my ps2 is really old 8 years. at first 1-3 yrs ago it works fine but a little difficult to turn the game on because if fail sometimes and 4-7 yrs ago it's now really difficult to turn the game on i kept restarting it like the game plays at 15%. And now in 8 yrs it now didn't work to turn on the ps2 so i got a major problem, I know my PS2 is very old but is there any idea what to replace it with? My email is rapha_raphael54@yahoo.com so please send me a message thanks you.
