Ir para o conteúdo principal
PlayStation 2 Disc Tray Belt Replacement
O que você precisa
  1. PlayStation 2 Disc Tray Belt Replacement, Remove the disk dirver: passo 1, imagem 1 %32 PlayStation 2 Disc Tray Belt Replacement, Remove the disk dirver: passo 1, imagem 2 %32
    • Open the console case and remove the disk driver.
    • Be careful with the flat cables and its connectors.
  2. PlayStation 2 Disc Tray Belt Replacement, Remove the protection: passo 2, imagem 1 %32 PlayStation 2 Disc Tray Belt Replacement, Remove the protection: passo 2, imagem 2 %32 PlayStation 2 Disc Tray Belt Replacement, Remove the protection: passo 2, imagem 3 %32
    • Remove the disk tray and remove the gear plastic conver protection.
    • You dont need to remove any gear form its place.
    • Remove the old belt and replace with a new one.
    • The belt must be a PS2 fat compatible belt. If you don't have a PS2 you can use a radio K7 driver belt but it need to have the same diameter of the PS2 belt.
    • Old and lax belt.
    • Brand new belt.
  3. PlayStation 2 Disc Tray Belt Replacement, Clean the lens: passo 3, imagem 1 %32
    • Don't loose the opportunity and clean the laser lens with a cotton swab.
Linha de Chegada
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 47
Últimos 30 dias: 197
Duração total: 1,063
