Ir para o conteúdo principal
Plantronics CS50 Headset System Reset
  1. Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: passo 1, imagem 1 %32 Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: passo 1, imagem 2 %32
    • Press and hold both the call control button and the listening volume/mute button for five seconds.
    • When the talk indicator light blinks, release both buttons.
  2. Plantronics CS50 Headset System Reset: passo 2, imagem 1 %32
    • Press the call control button again.
  3. Plantronics CS50 Headset System Reset: passo 3, imagem 1 %32 Plantronics CS50 Headset System Reset: passo 3, imagem 2 %32
    • Unplug the base unit's power source for ten seconds.
    • Plug the power source back in.
Linha de Chegada
3 outras pessoas executaram este guia.
Joe
Membro desde: 04/12/12
99 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 17-29, Amido Spring 2012 Membro de Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
Membros da 4
Autoria de 7 guias
4 comentários
Great fix. I was about to spend $200 on a new set. Thanks.
acseko - Responder
I had a constant buzzing sound from the unit. I did what you recommended and could not stop it. Then I discovered that my handset also had the same buzzing sound so I unplugged the phone line and power cord (to the main phone unit) and it cleared up!
Russ - Responder
I've got a unit that is getting no sound to or from the earpiece at all, though the lifter still lifts when I hit the answer button. I'll try this reset before I order a replacement set.
kool1zero - Responder
I have the C053 model and have cleaned headset and base and can not get it to charge. I have noticed over the past few weeks that it will only stayed charged from 800 am to 100 pm. I have disconnected and restarted also. Any other suggestions?
Diane
Diane - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 62
Duração total: 22,278
