Ir para o conteúdo principal
Plantronics CS50 Headset Battery Replacement
O que você precisa
  1. Plantronics CS50 Headset Battery Replacement, Battery: passo 1, imagem 1 %32 Plantronics CS50 Headset Battery Replacement, Battery: passo 1, imagem 2 %32 Plantronics CS50 Headset Battery Replacement, Battery: passo 1, imagem 3 %32
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
  2. Plantronics CS50 Headset Battery Replacement: passo 2, imagem 1 %32 Plantronics CS50 Headset Battery Replacement: passo 2, imagem 2 %32 Plantronics CS50 Headset Battery Replacement: passo 2, imagem 3 %32
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
Conclusão
To reassemble your device, follow these instructions in reverse order
Equipe
Cal Poly, Team 17-29, Amido Spring 2012 Membro de Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
Membros da 4
Autoria de 7 guias
Um comentário
I created the article https://de.ifixit.com/Artikel/Battery_Pl... for a Silvercrest bluetooth transmitter, but I was not able to change the needed parts of this howto to link to that article.
anton2 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 43
Duração total: 7,361
