Ir para o conteúdo principal
Planet Eclipse Etha Trigger Replacement
O que você precisa
  1. Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: passo 1, imagem 1 %32 Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: passo 1, imagem 2 %32
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Planet Eclipse Etha Trigger Replacement: passo 2, imagem 1 %32
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  3. Planet Eclipse Etha Trigger Replacement: passo 3, imagem 1 %32 Planet Eclipse Etha Trigger Replacement: passo 3, imagem 2 %32
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  4. Planet Eclipse Etha Trigger Replacement, Trigger: passo 4, imagem 1 %32
    • Use a hex key to unscrew the middle screw on the top of the trigger.
  5. Planet Eclipse Etha Trigger Replacement: passo 5, imagem 1 %32
    • Use same hex key to push through trigger retention pin on the side of the gun.
  6. Planet Eclipse Etha Trigger Replacement: passo 6, imagem 1 %32 Planet Eclipse Etha Trigger Replacement: passo 6, imagem 2 %32
    • Pull out the trigger by grabbing the bottom and slowly rotating outwards.
Conclusão
Uma outra pessoa concluiu este guia.
Evan Hench
Membro desde: 10/19/14
211 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-42, Amido Fall 2014 Membro de Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 940
