Ir para o conteúdo principal
Planet Eclipse Etha Battery and Grip Panels Replacement
O que você precisa
  1. Planet Eclipse Etha Battery and Grip Panels Replacement, Battery and Grip Panels: passo 1, imagem 1 %32 Planet Eclipse Etha Battery and Grip Panels Replacement, Battery and Grip Panels: passo 1, imagem 2 %32
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Planet Eclipse Etha Battery and Grip Panels Replacement: passo 2, imagem 1 %32
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  3. Planet Eclipse Etha Battery and Grip Panels Replacement: passo 3, imagem 1 %32 Planet Eclipse Etha Battery and Grip Panels Replacement: passo 3, imagem 2 %32
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
Conclusão
Uma outra pessoa concluiu este guia.
Jared Olson
Membro desde: 10/14/14
211 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-42, Amido Fall 2014 Membro de Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 1,216
