Ir para o conteúdo principal
Pipo Smart S1 Battery Replacement
O que você precisa
  1. Pipo Smart S1 Battery Replacement, Battery: passo 1, imagem 1 %32 Pipo Smart S1 Battery Replacement, Battery: passo 1, imagem 2 %32 Pipo Smart S1 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Insert an iFixit opening tool between the body and display of the tablet at the bottom of the device where the charging port is.
    • Slide the tool along the gap you are creating, moving to the right direction against the mini USB port.
  2. Pipo Smart S1 Battery Replacement: passo 2, imagem 1 %32
    • Gently pry the body of the tablet and pop the back cover open.
    • Lift the back cover of the device and place it on the side.
  3. Pipo Smart S1 Battery Replacement: passo 3, imagem 1 %32
    • Lift the edge of the white tape with the iFixit opening tool.
  4. Pipo Smart S1 Battery Replacement: passo 4, imagem 1 %32 Pipo Smart S1 Battery Replacement: passo 4, imagem 2 %32
    • Lift the white tape with your fingers, then lift the yellow tape that holds the battery extension.
  5. Pipo Smart S1 Battery Replacement: passo 5, imagem 1 %32
    • On the bottom of your tablet, use the Phillips #0 screwdriver to take the two 3mm screws out.
  6. Pipo Smart S1 Battery Replacement: passo 6, imagem 1 %32 Pipo Smart S1 Battery Replacement: passo 6, imagem 2 %32
    • Lift the headphone jack and move it to the other side, placing it on the surface you are working on.
  7. Pipo Smart S1 Battery Replacement: passo 7, imagem 1 %32 Pipo Smart S1 Battery Replacement: passo 7, imagem 2 %32
    • Use a spudger to pry the battery and detach it from the glue underneath it.
    • Be careful not to pinch the battery—lithium batteries are hazardous and prone to short circuiting, and thus burning and/or exploding.
  8. Pipo Smart S1 Battery Replacement: passo 8, imagem 1 %32
    • Lift the battery and place it a little further away from the positive and negative battery wires.
  9. Pipo Smart S1 Battery Replacement: passo 9, imagem 1 %32
    • Using your soldering iron, melt the two lead spots to detach the wires.
    • The soldering iron is extremely hot, so handle with caution. Always keep the soldering iron holder next to you when using it so you can return it easily.
    • When reassembling, make sure you solder the right pole to the right spot on the circuit board, as swapping them can burn the motherboard.
  10. Pipo Smart S1 Battery Replacement: passo 10, imagem 1 %32 Pipo Smart S1 Battery Replacement: passo 10, imagem 2 %32
    • Remove the two wires. Then remove the battery completely from the device.
    • Make sure you tape the negative and positive battery wires to keep them from short-circuiting.
Conclusão
Ali Alqallaf
Membro desde: 09/28/16
340 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 3-6, Passmore Fall 2016 Membro de USF Tampa, Team 3-6, Passmore Fall 2016
USFT-PASSMORE-F16S3G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 983
