Ir para o conteúdo principal
Pioneer Steel Wheels Headphone Headband Replacement
O que você precisa
  1. Pioneer Steel Wheels Headphone Headband Replacement, Headband: passo 1, imagem 1 %32 Pioneer Steel Wheels Headphone Headband Replacement, Headband: passo 1, imagem 2 %32
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Headphone Headband Replacement: passo 2, imagem 1 %32 Pioneer Steel Wheels Headphone Headband Replacement: passo 2, imagem 2 %32
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Headphone Headband Replacement: passo 3, imagem 1 %32 Pioneer Steel Wheels Headphone Headband Replacement: passo 3, imagem 2 %32 Pioneer Steel Wheels Headphone Headband Replacement: passo 3, imagem 3 %32
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
Conclusão
Garrett Leung
Membro desde: 04/16/13
955 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 10-40, Amido Spring 2013 Membro de Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
Membros da 4
Autoria de 37 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 1,131
