Introdução
This guide will show you the steps to remove the folding hinges at the bast of the headband.
Peças
Não são necessárias peças.
  1. Remove the two screws on the underside of the headband with the PH0 Phillips screw driver. Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband. With force, pull upwards.
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Remove the rail-piece that is now sticking up by pulling it up and out of the headphone. Repeat on the opposite side and the headband will be released. During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
  4. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. While holding the base of the headband with one hand, hold the ear cup with the other hand. Pull them apart to reveal the screw.
    • While holding the base of the headband with one hand, hold the ear cup with the other hand.
    • Pull them apart to reveal the screw.
  6. While apart, remove the screw from the headphone. While apart, remove the screw from the headphone.
    • While apart, remove the screw from the headphone.
  7. Loosen the plastic cover piece that protects the chrome folding hinge. Remove the plastic cover piece.
    • Loosen the plastic cover piece that protects the chrome folding hinge.
    • Remove the plastic cover piece.
    • During reassembly, make sure the plastic covering piece hooks onto the base of the chrome hinge before screwing it back in.
  8. Holding the ear cup with one hand, pull up on the base of the headband with the other hand to release the folding hinge. Repeat for the opposite side if necessary.
    • Holding the ear cup with one hand, pull up on the base of the headband with the other hand to release the folding hinge.
    • Repeat for the opposite side if necessary.
Conclusão
Garrett Leung
883 reputação
8 Guides authored
Equipe
Cal Poly, Team 10-40, Amido Spring 2013 Membro de Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Membros
20 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 281
