Ir para o conteúdo principal
Pioneer MXT-X366BT Metal Case Replacement
O que você precisa
  1. Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: passo 1, imagem 1 %32 Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: passo 1, imagem 2 %32
    • Apply small amount of pressure inward with a plastic opening tool to release bottom clip.
    • Pry the top clip with the plastic opening tool to release it.
    • The head unit is symmetrical and has the same amount of clips on the other side.
  2. Pioneer MXT-X366BT Metal Case Replacement: passo 2, imagem 1 %32
    • Remove the face plate holder.
  3. Pioneer MXT-X366BT Metal Case Replacement: passo 3, imagem 1 %32
    • Remove the six 5mm Phillips-head screws with Philips #2 screwdriver.
  4. Pioneer MXT-X366BT Metal Case Replacement: passo 4, imagem 1 %32 Pioneer MXT-X366BT Metal Case Replacement: passo 4, imagem 2 %32
    • Remove the inner three 5mm Phillips head screws, with a Phillips #2 screwdriver, attached to the metal backing.
    • Remove the metal backing that is now free.
  5. Pioneer MXT-X366BT Metal Case Replacement: passo 5, imagem 1 %32
    • Carefully slide the metal casing forward.
    • Metal piece standing is the rear of the head unit.
    • Edges are sharp.
  6. Pioneer MXT-X366BT Metal Case Replacement: passo 6, imagem 1 %32
    • Lift the metal casing from the rear and pull it away.
    • Edges are sharp.
  7. Pioneer MXT-X366BT Metal Case Replacement: passo 7, imagem 1 %32
    • The metal casing is now fully removed.
Conclusão
Uma outra pessoa concluiu este guia.
Blaine Kaiser
Membro desde: 03/22/18
169 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 278
