Ir para o conteúdo principal
Pioneer FH-X730BS USB Port Replacement
O que você precisa
  1. Pioneer FH-X730BS USB Port Replacement, Deck Buttons: passo 1, imagem 1 %32 Pioneer FH-X730BS USB Port Replacement, Deck Buttons: passo 1, imagem 2 %32 Pioneer FH-X730BS USB Port Replacement, Deck Buttons: passo 1, imagem 3 %32
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS USB Port Replacement: passo 2, imagem 1 %32 Pioneer FH-X730BS USB Port Replacement: passo 2, imagem 2 %32 Pioneer FH-X730BS USB Port Replacement: passo 2, imagem 3 %32
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. Pioneer FH-X730BS USB Port Replacement: passo 3, imagem 1 %32 Pioneer FH-X730BS USB Port Replacement: passo 3, imagem 2 %32 Pioneer FH-X730BS USB Port Replacement: passo 3, imagem 3 %32
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  4. Pioneer FH-X730BS USB Port Replacement, USB Port: passo 4, imagem 1 %32
    • Here you are able to desolder the USB ports from the circuit board and solder a replacement USB port on.
    • The end of the soldering iron will be hot.
Conclusão
Cody Pesta
Membro desde: 09/17/18
688 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,142
