Pular para o conteúdo principal
Introdução
Overheating can cause the Pioneer Elite PRO-R06U to unexpectedly shut off during operation. A broken
cooling fan will make it difficult for the media receiver to dissipate heat, and is the most likely cause of overheating. This guide will show you how to replace the optical drive cooling fan.
Peças
Nenhum componente especificado.
  1. Remove the two 6.4 mm Phillips screws on each side of the device's casing.
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Remove the two 6.5 mm Phillips screws on the back of the device casing.
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
  3. Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  5. To replace the optical drive cooling fan, grip the ribbon connector at M11 and gently remove by pulling away for the slot.
    • To replace the optical drive cooling fan, grip the ribbon connector at M11 and gently remove by pulling away for the slot.
  6. Flip the latch on the ribbon connector upward to allow for cable removal.
    • Flip the latch on the ribbon connector upward to allow for cable removal.
    • Grip the ribbon cable and remove by gently pulling away from the unlatched connector.
  7. Remove the two 6.4 mm Phillips mounting screws on the optical drive cooling fan.
    • Remove the two 6.4 mm Phillips mounting screws on the optical drive cooling fan.
  8. Grip the frame of the cooling fan and slide it toward the front panel, then lift out of the device.
    • Grip the frame of the cooling fan and slide it toward the front panel, then lift out of the device.
Conclusão
Cody Carter
Membro desde: 30-01-2018
1.049 reputação
6 Guias de autoria
Equipe
Baylor, Team S1-G5, Johnson Spring 2018 Membro de Baylor, Team S1-G5, Johnson Spring 2018
BU-JOHNSON-S18S1G5
3 Membros
6 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 58
