Ir para o conteúdo principal
Pioneer Elite PRO-RO6U Cooling Fan Replacement
O que você precisa
  1. Pioneer Elite PRO-RO6U Cooling Fan Replacement, Power Supply Cooling Fan: passo 1, imagem 1 %32
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Pioneer Elite PRO-RO6U Cooling Fan Replacement: passo 2, imagem 1 %32
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
  3. Pioneer Elite PRO-RO6U Cooling Fan Replacement: passo 3, imagem 1 %32
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. Pioneer Elite PRO-RO6U Cooling Fan Replacement: passo 4, imagem 1 %32
    • To replace the back cooling fan, grip the ribbon connector at slot M10 and remove by gently pulling upward.
  5. Pioneer Elite PRO-RO6U Cooling Fan Replacement: passo 5, imagem 1 %32
    • Remove the two 6.5 mm Phillips mounting screws at the back of the device.
  6. Pioneer Elite PRO-RO6U Cooling Fan Replacement: passo 6, imagem 1 %32
    • Grip the frame of the cooling fan and slide away from the back wall until the tabs are no longer in the holes of the casing.
    • Lift the cooling fan out of the device.
Conclusão
Cody Carter
Membro desde: 01/30/18
1.049 Reputação
Autoria de 6 guias
Equipe
Baylor, Team S1-G5, Johnson Spring 2018 Membro de Baylor, Team S1-G5, Johnson Spring 2018
BU-JOHNSON-S18S1G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 605
