Ir para o conteúdo principal
Pioneer A1 XW-SMA1-K Antenna Replacement
O que você precisa
  1. Pioneer A1 XW-SMA1-K Antenna Replacement, Back Panel: passo 1, imagem 1 %32
    • Use the spudger to remove the mesh front panel.
  2. Pioneer A1 XW-SMA1-K Antenna Replacement: passo 2, imagem 1 %32 Pioneer A1 XW-SMA1-K Antenna Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the thirteen 12 mm screws in the speaker frame.
    • Remove the speaker frame by pulling vertically upwards revealing the motherboard.
  3. Pioneer A1 XW-SMA1-K Antenna Replacement: passo 3, imagem 1 %32 Pioneer A1 XW-SMA1-K Antenna Replacement: passo 3, imagem 2 %32 Pioneer A1 XW-SMA1-K Antenna Replacement: passo 3, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the twelve 12 mm screws from the middle frame.
    • Remove the middle frame by pulling upward and vertically.
  4. Pioneer A1 XW-SMA1-K Antenna Replacement: passo 4, imagem 1 %32 Pioneer A1 XW-SMA1-K Antenna Replacement: passo 4, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove the nine 12 mm screws from the motherboard.
    • Flip the motherboard over.
    • Remove the motherboard by detaching the antenna.
  5. Pioneer A1 XW-SMA1-K Antenna Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove the motherboard from the speaker.
  6. Pioneer A1 XW-SMA1-K Antenna Replacement, Antenna: passo 6, imagem 1 %32 Pioneer A1 XW-SMA1-K Antenna Replacement, Antenna: passo 6, imagem 2 %32
    • Flip over the back panel and pull the antenna up and out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 533
