Introdução
This guide shows you how to replace a broken front glass and touch module but most disassembly steps are valid for other repair such as changing the screen as welll and can be easily adapted.
O que você precisa
Use the opening tool to lift the panel from the back cover
The panel is clipped to the frame so you should feel the clips release
Sliding the opening tool sideways after opening the first clips helps opening others
You will need to open clips on all 4 sides
Lift the panel out of the back and put it on a soft surface with the glass down without stretching the flex cable connecting the back and the mainboard
The element forming the three buttons will probably fall out at this point. Put it aside but remember to put it back into the back cover before closing the device
The wifi antenna is glued to the frame
Carefully peel it of without tearing it apart
It is sticky enough to hold again later without extra glue
Unscrew the speaker (mounted at the top with metal surfaces)
Lift the front camera out of its hole. It has no screws or clips
Move those parts inwards so they rest on the back of the LCD
Unscrew and lift aside the black plastic that holds the back camera in place
The camera itself can remain
Remove the washer screw holding the headphone jack in place (next to the camera)
Carefully lift the round sensor from its position in the frame
Remove the speaker cables from their trenches in the black support element, it may be covered by tape
Unscrew the element and put it aside
Remove the flat cable connecting the touch from the mainboard by flipping up the black latch holding it in place
Remove the screws holding the mainboard
Lift it up carefully to access the LCD clips underneath
Unclip the LCD panel from the front glass panel by carefully wedging an opening pick between the panel and the clips holding it in place
You can now swap the front glass and touch unit
The replacement unit has a protective foil on the inside. You need to remove that before installing the new glass
The foil started to leave residue on the glass so i used a hair dryer to weaken the glue
Congratulations you now have a touch device again
