Ir para o conteúdo principal
Pine64 PinePhone Motherboard Replacement
O que você precisa
  1. Pine64 PinePhone Motherboard Replacement, Place the device facing down: passo 1, imagem 1 %32 Pine64 PinePhone Motherboard Replacement, Place the device facing down: passo 1, imagem 2 %32
    • Place the device face down on a non-scratch surface.
    • Ensure the device is powered off before removing the case as removing the battery or making internal changes could cause physical or hardware damage to the phone
  2. Pine64 PinePhone Motherboard Replacement, Remove the back cover: passo 2, imagem 1 %32
    • Using a fingernail pry open the back cover off with the bottom left indent.
    • A notch to easily remove the cover is located at the bottom left of the PinePhone with the back cover facing the user.
  3. Pine64 PinePhone Motherboard Replacement, Battery: passo 3, imagem 1 %32
    • Using a fingernail, press into the bottom divot and remove the battery from the phone.
  4. Pine64 PinePhone Motherboard Replacement, Motherboard: passo 4, imagem 1 %32
    • Use a spudger or plastic opening tool to pry off the plastic cover.
  5. Pine64 PinePhone Motherboard Replacement: passo 5, imagem 1 %32
    • Use a spudger to lift the ZIF tabs and press-fit connectors free.
  6. Pine64 PinePhone Motherboard Replacement: passo 6, imagem 1 %32
    • Use a spudger to lift the motherboard up and remove it from the device.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 45
Ao todo: 1,462
