Ir para o conteúdo principal
Pine64 PinePhone Front and Rear Camera Replacement
O que você precisa
  1. Pine64 PinePhone Front and Rear Camera Replacement, Back Cover: passo 1, imagem 1 %32 Pine64 PinePhone Front and Rear Camera Replacement, Back Cover: passo 1, imagem 2 %32
    • Place the device face down on a non-scratch surface.
  2. Pine64 PinePhone Front and Rear Camera Replacement: passo 2, imagem 1 %32
    • Using a fingernail pry open the back cover off with the bottom left indent.
  3. Pine64 PinePhone Front and Rear Camera Replacement, Battery: passo 3, imagem 1 %32
    • Using a fingernail, press into the bottom divot and remove the battery from the phone.
  4. Pine64 PinePhone Front and Rear Camera Replacement, Motherboard: passo 4, imagem 1 %32
    • Use a spudger or plastic opening tool to pry off the plastic cover.
  5. Pine64 PinePhone Front and Rear Camera Replacement: passo 5, imagem 1 %32
    • Use a spudger to lift the ZIF tabs and press-fit connectors free.
  6. Pine64 PinePhone Front and Rear Camera Replacement: passo 6, imagem 1 %32
    • Use a spudger to lift the motherboard up and remove it from the device.
  7. Pine64 PinePhone Front and Rear Camera Replacement, Front and Rear Camera: passo 7, imagem 1 %32
    • Use a spudger to remove the rear camera.
  8. Pine64 PinePhone Front and Rear Camera Replacement: passo 8, imagem 1 %32
    • Use a spudger to remove the front camera.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 370
