Ir para o conteúdo principal
Pine64 PinePhone Battery Replacement
O que você precisa
  1. Pine64 PinePhone Battery Replacement, Place the device facing down: passo 1, imagem 1 %32 Pine64 PinePhone Battery Replacement, Place the device facing down: passo 1, imagem 2 %32
    • Place the device face down on a non-scratch surface.
    • Ensure the device is powered off before removing the case as removing the battery or making internal changes could cause physical or hardware damage to the phone
  2. Pine64 PinePhone Battery Replacement, Remove the back cover: passo 2, imagem 1 %32
    • Using a fingernail pry open the back cover off with the bottom left indent.
    • A notch to easily remove the cover is located at the bottom left of the PinePhone with the back cover facing the user.
  3. Pine64 PinePhone Battery Replacement, Battery: passo 3, imagem 1 %32
    • Using a fingernail, press into the bottom divot and remove the battery from the phone.
Conclusão
1Comentário do guia
I have all ready done this and my Pinephone doesn't work. It seems that I wasted a lot of money on a piece of junk and it's best for me not to buy another Pine64 product and convince as many people as possible not to do business with Pine64.
GunnyGee - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 87
Ao todo: 3,621
