Introdução
Rear wheel removal is required to change the tire or access the rear brakes.
O que você precisa
Loosen the exhaust strap:
Use an 12mm wrench to loosen the exhaust band lock nut.
A 6mm Allen key is required to unscrew the bolt at the bottom of the band.
Once the bottom of the strap is loose, you can push it upward and slide the retaining pin that secures the top of the strap out to release it.
Remove the 15mm nut securing the upper front corner of the swingarm.
Remove the 15mm nut securing the lower front corner of the swing arm.
Remove the 24mm rear hub nut. Having a friend hold the rear brake handle will help break it loose. You can also use an impact wrench to remove it if you cannot get enough torque with a hand ratchet.
There is a spacer behind the rear hub nut. It will slide off with little or no force.
Remove the five 10mm bolts securing the rear wheel.
Pull the wheel towards you, sliding it free of the rear axle.
The rear wheel hub nut is 24 mm. The tools needed listed the required socket as 22mm, but isn’t the right size. But it was my error not reading all the instructions. Just need to take another run to Princess Auto for the correct Socket in the morning. Fantastic post and very helpful.
5 outras pessoas executaram este guia.
Um comentário
This is perhaps the best written diy that i have come across. As someone who has penned procedures for many items I take my hat off to you. Keep up the quality work. I would add to soak everything down with a “nutbuster spray and let soak before beginning. Sometimes things are a little too easily broken, especially cast items.
jhrichaiii@aol.com
