Ir para o conteúdo principal
Photive Rain Speaker Replacement
O que você precisa
  1. Photive Rain Speaker Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
  2. Photive Rain Speaker Replacement: passo 2, imagem 1 %32
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
  3. Photive Rain Speaker Replacement, Speaker: passo 3, imagem 1 %32
    • Carefully remove the front panel from the device.
  4. Photive Rain Speaker Replacement: passo 4, imagem 1 %32
    • Detach the connector clips from the motherboard using the iFixit Opening Tool.
    • Some force may be necessary to remove the plastic clips.
  5. Photive Rain Speaker Replacement: passo 5, imagem 1 %32 Photive Rain Speaker Replacement: passo 5, imagem 2 %32
    • After the speaker is detached, remove the two 8.5mm screws that hold the speaker to the front panel with a Phillips #1 screwdriver.
Conclusão
abcdef ghijk
Membro desde: 02/15/16
723 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team 1-4, Harley Spring 2016 Membro de IUPUI, Team 1-4, Harley Spring 2016
IUPUI-HARLEY-S16S1G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 307
