Introdução
Does the audio coming from your device sound rough? Does your device not emit any audio and you've ruled out the battery or the volume as the cause? Then the speaker may be the problem. This guide goes through the steps necessary to remove the speaker from your Photive Rain device so you can replace the speaker.
O que você precisa
