Introdução
This is a guide to show how to remove/replace the USB-A & USB-C port in your Philips TAS7505 Speaker. The only tools you need are a Phillips #0 Screwdriver and an iFixit Opening tool.
Notice the steps from our Outer Shell Disassembly guide are included, this is crucial to get the inner screws of the port.
O que você precisa
Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
